Question about Whirlpool Dryers
I have a Whirlpool Duet electric dryer (WED9400SW2) when it spins it makes a continual load squeaking noise. It's only three years old.
  • 17 Answers
SOURCE: Whirlpool Duet Electric Dryer (5yrs old)
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Posted on Dec 10, 2007
  • 50 Answers
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Posted on Jan 25, 2009
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
jsrock516
  • 5911 Answers
SOURCE: I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Posted on Sep 01, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
Why does my whirlpool duet dryer door keep popping open? After a few minutes, the top latch of the dryer pops open and the dryer stops. Visual inspection of the dryer yields no issues. The door has...
The latch is shot I would replace both top and bottom. Most of the time all you need is a needle nose plier to perform the task. There are some good tutorials online that walk you through the steps. The actual latches a fairly inexpensive and you should be able to find them from a supply store that specifies in home appliance repair.
Jul 28, 2014 | Whirlpool WED9400S Electric Dryer
I have a Whirlpool Duet Dryer about 4 years old. It just began making a screeching sound at startup. I say startup because it subsides after awhile. It sounds like a bad bearing , but acts like its a bad...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 06, 2011 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Duet Dryer (Model EW9200LL1) that is about five years old. It is getting increasingly noise when drying--sounds like a belt or bearing issue. Is this something I can troubleshoot/repair...
heatman101
Asker
Nov 22, 2010 | Whirlpool Dryers
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool WED5821 electric dryer. The dryer is only 3 years old. When it is drying it is making a high pitch noise. When it first started it would be heavy loads. Now it doesn't matter the...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 08, 2010 | Whirlpool WED5821S Electric Dryer
My dryer is spinning and heating, but is making a knocking noise.
heatman101
Apr 27, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
We have a whirlpool duet washing machine that is about 7 years old. During trhe spin cycle it makes a loud noise. Not the typical "airplane noise." There is also an odor. A burning engine odor. If you...
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
166 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
