Question about Shure 55SH Series II Professional Microphone
Loved it but in about 2 weeks after no use it would not work. Sounded like the cable was not connecting...tried it with 4 other cables..no connection. Is it the switch?
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Contact Shure for repairs.
Posted on Jul 27, 2014
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
I borrowed my brother-in-law's ps3 while he was away for a few weeks. it worked fine on my tv but when he got back, it didn't work on his. i have an HDTV but he has a regular one. i've looked for answers...
Alright so this is what you have to do.
1. Connect it to your HDTV with the HDMI cable and the red/white/yellow cable.
2. Turn it on and go to the display settings and switch it to the composite cable setting.
3. Change your TV channel where you would see the red/white/yellow cable and accept it that way.
4. You should be all set. Take it to the regular TV and connect it with the red/white/yellow cable.
Jan 10, 2011 | Sony Playstation 3 (PS3) Console
Sharp 26'' LCD HD screen went white, sound is fine
Go ahead and try unplugging the video (yellow) cable and plugging it back in.
If that doesnt work, do you have any spare video cables try those.
Then unplug your tv for 2 mins and hope for the best.
GOOD LUCK.
CNBY
Jun 03, 2010 | Televison & Video
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Can't establish connection by cable
Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
Apr 11, 2010 | D-Link DIR-300 Wireless Router
Last week I put a 4-hub on my desktop and laptop. one wire from wall to main hub, one ethernet cable from hub to laptop, one ethernet cable from hub to rear ethernet port on desktop. The internet on the...
check if we are getting good ip address 192.xxxxxxxxxxxxxxxxxx
not the 169.xxxxxxxxxxxxxx
relese renew if 169.xxxxxxxx is the case
if no reply.. try using another cable and check the connections
Sep 20, 2009 | Dell Latitude D600 Notebook
Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Feb 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My cd/dvd drive does not work - previously working fine - could be after trying to copy a dvd a couple of weeks ago. any ways i can prevent reformatting hard drive and reloading xp again. everything else...
you should,nt have to re-format or setup xp again.
1:) check the computer for viruses. viruses-trojans et,c malicious software can lock off drives.
2:) go into start/control panel/system/device manager.
click on cd/dvd drive if it,s there, uninstall it. restart the computer, you should then get a message new hardware found.
install drivers as necessary.
3:) check the drives cables. the 4 pin molex connecter ( plastic block ) with 1 red 1 yellow 2 blacks, to ensure it,s connected correctly. or try an alternative one if available.
Also check the 40-80 pin ide cable.
4:) try a secondary cable ( 40 pin ) on the secondary connector from the motherboard ( if not in use ) set drive as a master.
Hope this helps.
Mike @ compurepair.
Mar 29, 2008 | Televison & Video
4 flashing red lights
4 lights means the AV cable cannot be detected. Here are a list of things to try
1. Make sure your video cable is plugged in firmly. Unplug it and plug it back in. Could just be a loose connection.
2. Try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV pack again.
3. Your AV cable may be bad. Try a different one if you have a spare. If you don't, I suggest you go get one before sending your xbox in for 3 weeks.
Mar 22, 2008 | Microsoft Xbox 360 Console
Color and brightness problem
Has it been dropped? At first it sounded like it may be have been an intermittent short if the CRT guns, but it's hard to say. Since it doesn't seem to be the cable, it sounds like this one needs component-level troubleshooting.
Jan 07, 2007 | LG Flatron F700B 17" CRT Monitor
Shure 55SH Series II Professional Microphone Logo
56 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
