Question about Rowenta Steam 'n Press DA75 Iron
How do I put water in it - Rowenta Steam 'n Press DA75 Iron
How do I put water in the steamer?
it turns counter clockwise .
Nov 27, 2015 | Irons
How do i descale a team international steam pro 2600w iron
Buy a bottle of descaler and put it in the tank where you normally put the water. Put iron on hottest steam poison and run steam , topping up as required. Rinse thoroughly when finished and iron has cooled. Use distilled or demineralised water for steaming and the iron shouldn't require cleaning again.
Dec 02, 2014 | Irons
How to fix a leaking water out where you put the water in the iron
Strip the whole iron and inspect that water bottle you will see how you can close it or you can use it without putting water ucan wet the cloth first
Sep 12, 2014 | Conair Irons
Cloudy water tank. can't tell when it is full
fill it with a solution of distilled water and white vinegar and let it soak for 24 hours. Then rinse it out a few times with distilled water and only use distilled water going forward.
Mar 29, 2014 | Rowenta Powerglide DM253 Iron
Steam tank
Make sure the iron is turned off. Then pour water in the opening to the tank untill it is about 1/2 full. then put the lid on the tank.
Sep 17, 2013 | Euro-Pro EP5100 Iron
How to open the water tank in the black and decker iron ir1375sc
Regarding the Black & Decker Iron. You all talk about how to put water in the iron but none answer the question how to do that? What part do we remove or open to change or put in the water? Please answer this as soon as possible. This will also be on my Facebook to anyone there can you too help me?
Dec 24, 2012 | Irons
My Morphy Richards Jetstream is about 5 or 6 years old & works fine except that when I first use the steam I get brown water marks on items. This means I have to wash them again. What can I do to solve...
Try cleaning the inside of the water holder it might just be calcium built up, use white vinegar to clear it and you'll prolly be fine. Put vinegar where you usually put the water and heat the iron up and steam the vinegar through the iron then put water, try distilled water to save this problem from happening again or try filtered water.
Jun 08, 2011 | Morphy Richards Jet Stream 42271 Iron
Where do you put water in it?
The manual for this item is available here:
http://useandcaremanuals.com/pdf/C520695.pdf
You put the water in under the water cover located above the steam button.
Nov 25, 2009 | Black & Decker Gizmo C520 Iron
Rowenta Steam 'n Press DA75 Iron Logo
62 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
