Question about Maytag M6Q10F2A Air Conditioner
Coil Dirty How do you remove the front cover. Most just snap off. Do you have to remove some screws somewhere?
I have water leaking, where is the plug to drain it?
Posted on Aug 15, 2008
    Novelist:
  • 114 Answers
YES ... LOOK AROUND THE CONTROL PANEL. LOOK AROUND TOP ,BOTTOM,AND SIDES WIH-IN 1/2" OF THE COVER FOR SCREWS. AL SO AROUND THE FILTER AREA AND CONTROLS. GOOD LUCK
Posted on Sep 27, 2007
How do I remove the ECOTec 2.2 panel to get to the plugs
the cutie pie plastic panel on top of motor, ah unscrew it?
the FSM cover this step by step. (i think there is no cutie cover)
or alldata.com
some just say remove the cover , knowing the shop mech, can see the screws. if it snaps off, they might say that in the book.
think about that, if there are no screws, how would it attach./?
yes, snaps.
ah the spark rail.
alldata.colm
ign coil housing replacement.?
steps.
Disconnect the EI module harness connector.
Remove the ignition coil housing attachment bolts and remove the ignition coil housing.
with boots.
see the 4 bolts on to in plain sight? those.
then gently pry it up. so as not to break all this weak plastic bs.
put back with dielectric great as the FSM states.
or next time, comes off will fail.
Jun 24, 2014 | 2004 Chevrolet Malibu
Removing the covers on a viking 980
I assume you're talking about the main back and front cover. Unless you really are skilled, I'd leave this project to a professional.
I've worked on the Designer I, II type machine and I believe yours has similar construction. You need screwdriver bits with a 6 pointed "star" head. Screws in the cover itself are "H10" size. Screws in the base are "H15" size. The back cover has to be taken off first before you can get at screws for the front cover. Typically there are 5 screws on the back cover that have to be removed and 2 in the bottom of the base. Note that the front and back covers "snap" together and have to be unsnapped after the screws are removed. If you have to take off the front cover (requires removing more screws in the cover and base), be careful with the various wiring harnesses that attach to the main circuit board.
Jan 13, 2013 | Husqvarna Viking 1
Manual for replacing lamp for 60v500a
1. Turn off the main power switch and unplug the power cord. Wait at least 30 minutes to allow the lamp to cool down before
replacing it.
2. Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on
disengages.
3. Remove the screw securing the lamp cover with a Phillips head screw driver. Remove the lamp cover.
4. Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.
Exercise caution when removing the lamp unit to avoid injury to your fingers.
5. Replace with the new lamp.
Place the removed lamp into the empty box of the replacement lamp. Do not touch the front glass of the new lamp or its
receptacle. This may shorten the life of the lamp and reduce the picture quality.
• Push the lamp unit back to its original position.
• Tighten the screws firmly on the lamp unit. If they are loose, the TV may not operate correctly.
6. Without installing the lamp cover, the power will be off and the Lamp Indicator will flash. Be sure to install the lamp
cover by re-engaging the two clips and tighten the screws before turning the power on, otherwise it may cause unusual colors.
7. Install the front cover. Put the front cover back in and align the snap on quick connect then push inwards holding
the left and right side of the front cover until you hear a snap. Push the other snap on gently to make a good fit.
8. Plug power cord into AC outlet and turn on the main power switch.
NOTE: The lamp in this product contains Mercury. Dispose of properly in accordance with applicable environmental
laws. For Recycling and Disposal information, contact your respective governmental agencies or the
Electronic Industries Alliance at www.eiae.org (in the U.S.) or Electronic Product Stewardship Canada at
www.epsc.ca (in Canada).
Jun 24, 2012 | Hitachi Lamp for Hitachi 60V500A -...
I let someone use the cleaner, and it came back dirty. How to I clean the front plastic where the water pulls the dirty water through. It is day and filthy. Help
There are three screws that hold the clear plastic cover in place. Turn the machine over and remove the two silver colored screws at the outer edges of the cover. To remove the third screw, remove the dirty water tank, and you will see a screw at the top center. After the screws are out it should be easy to pull the cover off for cleaning.
Apr 09, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How to remove front dopr panel on 1995 Lincoln Town Car
Front Door Panel - Town Car - Removal
CAUTION: To avoid breakage of door pull cover(s), insert a screwdriver diagonally between pull strap and chrome bracket. Snap out both sides then remove.
Snap out two door pull strap retaining screw covers. Remove screws.
Remove two screws on front and rear side of front door trim panel.
The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel (23942) to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from back of front door trim panel . Lift up housing, remove retaining screws and disconnect all connectors.
Disconnect driver seat regulator control processor switch (driver door only) if equipped.
Twist out interior lamp wire assembly and remove the front door trim panel.
Installation
Ensure plastic watershield is secured to door panel.
Position front door trim panel to door. Connect interior lamp wiring.
Position the window regulator control switch housing and connect switch connectors. Install the retaining screws.
Connect driver seat regulator control processor (14C708) (driver door only) if equipped.
Align door lock side to its mating slide on the sheet metal (front doors only).
Snap in front door trim panel. Ensure all retainers fit properly.
Install two retaining screws on front and rear side of front door trim panel .
Install two retaining screws and pull strap covers.
Good luck Remember rated this).
May 31, 2010 | Lincoln Town Car Cars & Trucks
2001 Ford Expedition window came off track
You did not mention whether it was a front or rear door? I assume its a front because u stated no screws.
Here are instructions for front door:
Remove the plastic trim from behind mirror(just snaps on).
Remove the window switch panel(just snaps on).
Remove the screw behind the mirror cover.
Remove the screw behind the window switch panel.
Remove the courtesy lamp lens.
Remove the screw in the courtesy lamp housing.
Remove the inside door handle trim cover.
Remove the inside door handle bolt.
Lift upward and then outward to remove the front door trim panel
Feb 10, 2009 | 2001 Ford Expedition
Front cover Removal
The colored front piece snaps off. Take a screw driver and carefully pry it. Snaps are at the top, around the drive bays, and at the botton. It would be easier to unscrew the case around the PC first. Make sure you unplug the PC first.
I am assuming you bought a new flashy colored replacement? If you are looking to get inside the PC then you unscrew the 2 screws on the back right, or right and left side, they will look different then the other screws, and slide off the case.
Oct 02, 2008 | Compaq Presario 5000 PC Desktop
Whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
HELP ME PLEASE!!!!!!!!!!! I CAN'T GET IT APART!!!!!!!!
Have you removed the battery, and checked for screws there? Looked under the memory cover. Chgeck the the two halvers of the shell are not 'snap' together?
Jun 24, 2007 | Acer Aspire 3003WLCi Notebook
Maytag M6Q10F2A Air Conditioner Logo
190 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
