Insignia TV picture went small to a box in the upper left hand corner. I have DirecTV and even the remote for that won't show it's doing anything in that small box in the corner.
5 Suggested Answers
SOURCE: Small black box in upper left corner of Sony TV - need to remove
I had a similar problem on my Toshiba Regza but trying my fix couldn't hurt. I use a satellite dish for TV (if you do the same this might work)... I turned off my receiver, took the programming card out, cleaned it with my shirt (especially the part that looks like a computer chip), put it back in the receiver, turned it back on and when everything reinitialized the black rectangle was gone.
Hope this helps.
Posted on Apr 13, 2010
  • 418 Answers
SOURCE: my tv picture is a small box on the upper right
Press PIP button, or press swap.
Posted on May 06, 2010
budmrtn
  • 11361 Answers
SOURCE: small black box in the upper left hand corner of
Look for PIP (Picture-In-Picture) on the remote to turn that function off.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 26, 2011
magnet0
  • 242 Answers
SOURCE: My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Posted on Dec 10, 2012
I pressed a button by mistake and my Sony tv has no picture. Now has small box left hand upper corner with A and lines like wifi icon
Try the RETURN button on the remote to get back to viewing.
Get the manual at Sony KDL 40S2010 Manuals See page 11 for remote control keys and page 38 for further trouble shooting if necessary
Jun 03, 2016 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do I disable PIP?
Some remotes allow PIP to be turned on and off but your initial set up routine may have to be revisited to prevent PIP from popping up uninvited.
Aug 18, 2015 | Televison & Video
Picture is not full screnn only upper left corner
not real clear what you have: if you have a small picture in upper corner look in menu for PIP and with remote turn it off(picture in picture will do that)
If not let me have a better description of what it is doing.
Mar 30, 2012 | Sceptre 32 X320BVHD 32 LCD TV
Need remote control code for 32" tv for direct tv remote
To reprogram your remote control there is a specific website available online for Direct TV owners. To get started, you will need to locate your model number and know the Brand name. The website will require you to enter that information in. The model number is printed in the upper left hand corner of your remote control. Then go to : http://www.directv.com/DTVAPP/content/remote_codes and follow the prompts from there. Your remote will be up and running in no time.
Spotsylady
Jun 15, 2011 | Televison & Video
I need to program my direct tv remote to my emerson 32inch flat screen tv. How do I do that.
There are a number of different remotes that Directv use, and instructions may differ from your particular model. If you look at the upper left hand corner on the face of the remote there will be a model # RC-64, RC-23, RC-24, RC-32RF, etc. Click on the link HERE and on the webpage, scroll down and you will find the instructions to program your specific model DirecTV remote for your Emerson TV. I hope this helps and good luck!
Feb 17, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
I can not get the emmerson tv i have to go into video mode. I do not have the origional remote that came with the tv or the manual. The remote i have is programed with direc tv. how do i get the tv into...
In the upper left hand corner of the DirecTv remote there is a button labeled "TV INPUT" just push that button. Each time you push it it will change the inputs for the TV. If that is not the problem, the remote needs to be programmed with a code for your TV. If that is the case push the MENU button under the circle in the middle of the remote. Scroll down to PARENTAL, FAV'S, & SETUP, push the yellow SELECT button in the middle of the circle, scroll down to SYSTEM SETUP, then scroll down to REMOTE and push the yellow SELECT button again. From there you should be right as rain. On my TV and setup, I have a device hooked up through DVI, but the TV won't recognize it unless it is powered on. In otherwords when pressing the TV input on my DirecTv remote it doesn't show the DVI device (PS3) unless it is powered on. I hope this helps and good luck. Please vote and leave a message.
Oct 30, 2009 | Emerson CR202EM9 TV
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
PIP
Look for a "PIP" (Picture In Picture) button on the remote or in the TV's menu. I suspect that it has been pushed but there is not a second source to view. That would explain the smaller version in the corner.
Apr 08, 2008 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
