Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony KDL32CX520 red light blink 8 times - Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
C-Dog
  • 84 Answers
SOURCE: 6 red light blinks-possible thermal fuse prob.
You need the location of the part that's stamped on the board near where it was soldered in. And you need a soldering tool to resolder the new part in and cut the excess wire with cutters so you're not to short out the circuit.
C-Dog
Posted on Feb 10, 2008
praky16
  • 744 Answers
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Posted on Apr 10, 2009
  • 87 Answers
SOURCE: sony wega 42e2000 red light blinkes 3 times
YOUR LAMP DOOR OR COVER IS OPEN OR WARPED
Posted on Apr 15, 2009
Kensolutions
  • 455 Answers
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jun 12, 2011
  • 430 Answers
SOURCE: Sony kdl-46w4150 standby blinks 8 times
Click the link below :----http://wikisolutions.blogspot.in/2012/02/get-free-answers.html
Posted on Feb 12, 2012
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Sony KDL32CX520 red light blink 5 times
IKR Error at power on 05. 5 blinks denotes this. Actually, the fault is related to its main digital board, and the work will not an easy one. Anyway, http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or view it in Timslide option, and see whether there is something to help you. If you're not sound in electronics, no need to proceed. Contact any service technician or authorized service centre for Sony.
Jun 29, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have sony KDL32CX520 model it happen to turn into blank scrren while watching tv but the sound works?whats the problem??
What do you mean by this blank screen. A screen with back light only? A screen without any back light [dark screen]? Provide more details please. If you wish to get details about these type of faults to Sony LCD TVs, check this link.
Feb 03, 2013 | Sony 32 inch KDL32CX520 Series Full HD...
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
11 blinks onSony KV24LS35U
According to the LED error code (11 times blinking) the problem is in "Jungle controller 8 volts" which are not being produce, this kind of fault bit technically difficult to and i suggest you to contact any expert to find the cause of not producing 8 volts supply,
Hope you will understand my sayings,
Thanks for using fixya.
Jul 25, 2009 | Sony Televison & Video
Sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
Mar 25, 2009 | Sony KDF-50E2000 50" HDTV
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
Status light blinking
your flyback is bad on the D board thats what makes the led blink 8 times replace the flyback and you should be fine. If you need a link on where to get the flyback and instructions on how to change it let me know and I will post a link
May 25, 2008 | Sony KP-53HS30 53" Rear Projection...
Red light flashes 8 times
i dont know the error code but my standby red light is blinking 8 times
Feb 10, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
