Question about GE 4.0 cu. ft. Front Load Washer - WCVH6800JWW
My GE front loader #WCVH6800JWW is making a loud grinding noise from the pump valve. I cleaned out the filter in the front it worked for about 5 min then went back to making the noise and not spinning.
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
SOURCE: Washing Machine Will not Spin
Every one needs to know that the expensive parts are under warranty for ten years the outer drum front and rear, the pulley, the inner drum.  GE sent me all four parts retail value 1200.00 on their web site, got them today.  Before I under take this project I am wondering if any one know if the drum seal the giant O ring ( the one between the two halves) should be replaced or can the old one be used?
Posted on Apr 17, 2008
SOURCE: ge washer not draining or spinning
Washer will not drain or spin. Got the water out andf tried it . It would spin and seem to drain what little was left in the drum. When I added about 1" of water it would not drian or spin. Drum sets at an angle also.
Posted on Oct 29, 2008
SOURCE: my ge front loader washer will not drain
We had same problem. The pump was all clogged up with fabric debris, and a part of a metal bra liner. I removed the pump and cleaned it out. Now it seems to work fine, and went through a complete cycle. Ther pump was accessed from the front, and was not too hard to remove.
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: how to clean out the Pump Filter on front load ge wcvh6600
for other models, like the GCVH6260, you remove the lower front panel, which is held on by 3 screws, and unscrew the filter, which is a round white plastic thingie on the right side. (unlike the video, there is no convenient flip down spout for the water to drain out.) be prepared to catch about a litre of water when opening the filter. a good-sized tray or bowl works, and have a cloth or towel handy to mop up any spillage.
slide it out, clean it, and slide it back in. on my machine the closed position was marked with a blue mark along the edge - it's a nylon plug with a rubber gasket, so apparently it doesn't need to be overtightened. just turn it back to the way it was.
Posted on May 09, 2011
LG- Front Loader making loud deep humming noise prior to draining.
I had the same problem. Loud noises during draining operation. It turned out to be the drain pump motor. The impeller that pumps the water wears out on the shaft, and then starts to flop around creating vibrations, and in turn the noises you hear. The pump is a very inexpensive part. $35-50. There is some work involved to get to it, and to replace it, but not overly complex. Just watch the motor wire connections. Take a picture with your camera/phone of the connections. I would recommend watching the youtube video in the link provided on how to get to the motor, as some of the steps can be challenging, especially the drum seal retaining ring removal and reinstallation steps. https://www.youtube.com/watch?v=8cPl22OC9f4 .
Good luck.
Apr 14, 2014 | LG Washing Machines
Whirlpool washer dryer has been making a grinding noise for a while and now won't drain
Hi.
The grinding noise was probably being caused by objects stuck in the drain filter. Disconnect power and check the drain filter. On Whirlpool front loaders the filter is accessed from the front of the machine. You will need to unscrew the filter cap and to remove blockage With top loaders the access is underneath or at the back. You lean the appliance on one side and disconnect the hose directly connected to the pump. Disconnect power before starting maintenance.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 10, 2011 | Washing Machines
Won't spin--just makes a grinding noise
Hi.
The grinding noise usually means that there are objects stuck in the drain pump filter.
with front loader the drain pump filter is often located behind an access door or a trim on the front side at the bottom. Open the door or remove the trim, then unscrew the cap. Be prepared to collect the water. Disconnect power before starting.
Top loaders have pump access from underneath or at the back.
Apr 26, 2011 | Washing Machines
My servis washing machine makes a loud grinding noise when the water drains whilst drum turning.
could be something in the pump as opposed to drum bearing fault....Try cleaning filter/check pump blades.....
Feb 24, 2011 | LG WM2077C XL Front Load Stackable Washing...
I have a he front loader washing machine. I cleaned the filter but it still wont drain. The pump makes a quiet humming noise but nothing happens
u have to have some one take your pump off i just did that and had a peice of broken of pencil in mine stuck works great now...
Feb 08, 2011 | GE Washing Machines
Makes growling noises throughout the cycle.
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Sep 25, 2009 | GE Dishwashers
Loud rattling grinding noise when pump is running, no water enters the machine.
Make sure the water is turned on to the machine, if it is then it sounds like a faulty water fill valve, just replace the fill valve, they can sometimes be cleaned but I would never trust one, they can always stick in the on position later and flood your house. Check to see if the valve is geting 120v ac before replaceing the valve, if it's getting voltage and no water is flowing then the valve is bad. You will need to borrow or buy a multi-meter for this test.
Feb 01, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE 4.0 cu. ft. Front Load Washer - WCVH6800JWW Logo
46 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
