Question about Plumbing
Goulds sewage pump submersible/page-2
TII industries Inc. EP0411 10 hp 115 V 12.oA K0173237
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: reset button for sta-rite well pump kicks off
That could be a bad wire in the well or the pump motor has a flat spot...or a spot that if the motor stops there it will not start....also could be that the pump bearings are worn and the motor locks up once in a while...
Bottom line the pump will need to be pulled and probably replaced....
http://www.fixya.com/support/r3755320-electric_problems_submersible_pumps
heatman101
Posted on Apr 22, 2010
leroywolff
  • 42 Answers
SOURCE: bn 266-b zoeller submersible sewage pump will not
Inside the pump there is a thermal overload switch. Normally the pump will start back up again after it cools off. If not the pump should be replaced. If you are desparate and don't want to buy a new one. You could try taking the pump all apart, find the thermal overload switch and replace it. I have never done that, but I'm sure it could be done. Just make sure to seal the pump good on the body gasket surface. 100 percent silicone should do it. After everything is working, I always use the cheapest latex caulk I can find, and seal the pit cover. Cheap caulk will pull up easy the next time
there is a rag in the pit.
Hope I have helped.
Posted on Nov 05, 2010
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Nov 06, 2014 | Goulds Pumps GOULDS GT20...
Burcam tankless jet pump wont turn on all lights are on
What is your model number on this, also you can contact directly at T 514.337.4415
Sep 01, 2014 | BURCAM Pumps BURCAM 3/4 HP Stainless Steel...
How to fix double starts from points kicking the breaker
If the breaker is tripping you need an electrician to check wiring, pressure switch shouldn't be a problem. Don't try to work your way around electrical, always remember the unit will last longer if electrical is running properly to unit.
Aug 31, 2014 | Goulds Pumps Goulds RGS2012PA -...
Stop after 5 minute
Is the pump underwater? I would guess this is a sewage pump since it is a 2" discharge. If it is not underwater it will get hot and trip thermal overload. Why is it running for 5 minutes? That is a lot of water to move assuming your not trying to lift it over 10".
Apr 02, 2014 | Liberty Pumps LE41A 4/10 HP Auto...
Our goulds pumps j5s is running very loud after we replaced our sewage ejection pump last week. Could these problems be connected?
Those pumps last a long time. I do not think the problems are connected. I am assuming you are pumping water up from the pump. The pump has a check valve in the discharge that may not be closing. Cleaning that should solve your problem. Be sure water will pass through the discharge line into the drain.
Feb 05, 2014 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Pump will not kick on after pressure drops. Just installed a new pressure switch and pressure tank.
Hi Tony
1. Check your opening to the pressure tank to make sure it is clear and reading the pressure in the tank.
2. Check to make sure that the pressure cut-off of the new pressure swith is at the correct shut-off pressure...if not then adjust...read the directions that was included in the box with the new pressure swith
Please take time to rate me
Bud
Mar 31, 2013 | Star Water Systems 1/2 HP Cast Iron...
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
Well pump running every 5 minutes
It can be water loged you need to drain some water out of your tank and put 35 psi air in it,
Aug 27, 2009 | Goulds Pumps WW0511A Goulds Sewage Pump...
I HAVE A 8 1/2 DIAMETER SUMP.MY OLD PUMP FAILED. CANNOT FIND A PUMP SMALL ENOUGH TO FIT.HELP!
get a submersible zoeller sump pump the flaot is attached to the pump not a teather and it wilol keep less water in the pit,, this is the best pump on the market
Jun 12, 2009 | Zoeller M211 Automatic Aqua-Mate...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
