Question about MagLite Xl200 LED Flashlight Black
Mag-lite led xl200 has ceased to function after several years inactivity in a briefcase. any suggestions? battery replacement has been tried
3 Suggested Answers
SOURCE: Mag lite
I have a regular AA Mag light that had industrial strength batteries which corroded.I did get them out but the bulb holder on the light broke.(The main bulb holder where the twist on switch is.)
Posted on Oct 03, 2008
dfbjr
  • 45 Answers
SOURCE: My mag lite led xl100 will not turn on, have fresh
take the bottom piece off, remove the last battery and put a coating of petroleum jelly on the threads of the tube. Then take the bottom piece and run it all the way in and back off and back in 2 or 3 times. Then put a little more petroleum jelly on the threads and put the battery back in and the bottom piece. This should do it.
Posted on Oct 25, 2012
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
My mag lite led xl100 will not turn on, have fresh batteries installed
Apr 10, 2011 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I just replaced the batteries in my 2 D LED maglite with duracell alkaline batteries and after about 5 minutes use seem to have blown the led. Torch is less than 1 year old and has had limited use. Looking...
The resistor needs to be disconnected at one end -- if the LED is removed this should have the same effect as disconnecting one end of the resistor.
Put the probes of an ohmeter on each end of the resistor -- if it reads 0 ohms (or near zero), it is shorted.
Charlie
Mar 26, 2011 | MagLite Mag-Lite& Flashlight
Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
How do i remove the led bulb in my 3D cell Mag-lite dl
http://www.takeitapart.net/archives/mag-lite-2d/
May 14, 2010 | Camping, Backpacking & Hiking
I have a five D cell Maglite. Seems to always
There are diffferent mag lite bulbs made for different amounts of batteries. Be sure that you have the 5 cell light bulb. Also try to keep your fingers off the glass. if you get any oils on it, wipe it off before turning it on.
Also you can get mag lite specific bulbs...they cost more but they're worth it.
Feb 03, 2010 | MagLite Flashlight Type: Black D Cell 5:...
I too cannot open the torch to replace batteries. B Abel 30/07/09
Used a large vice and mole grip, then hooked the corroded batteries out.
Jul 30, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have an AA Mini Maglite and it quit working. I replaced the two batteries and lamp and still does not work. Any suggestions?
I have several of these flashlights and experienced the same problem. Here's my solution: take off the light end and you will see a black base where the bulb is inserted into. The black base rotates. If all else is functional (batteries, bulbs, etc.), when you rotate this black base, the light should come on. Moving the base back and forth several times seems to help also (it seems there must be some kind of contact problem). All that's left is replacing the light end.
Jun 18, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Mag lite
Jun 12, 2008 | MagLite - Mag Charger System 110v (M)...
MagLite Xl200 LED Flashlight Black Logo
47 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
David Black
David Black
Level 1 Expert
 steve
steve
Alec Oren Orris
Level 1 Expert
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
