Question about Star Water Systems PowerFlush Sewage Ejector System S1101
We have a Star S1101 system that was installed in new basement bathroom by previous owner. When rarely used there is no problem. But when used at all, and just for "number 1" only, a sewage smell fills the basement. I have reviewed installation procedures and components, and everything seems to be in order. And ideal what may be wrong? Thank you.
Tip
How to raise the value of a home with a basement by a good percentage
If you are trying to sell a house with a basement and want to include rooms in the basement in the advertising their must be a way to exit the house from the basement. for a few thousand dollars now you can add the rooms and raise the value significantly. Egressed windows are windows in a basement large enough to qualify as an exit. You will have to call a concrete cutting contractor and have him cut out the window size. then install the window. now instead of your add saying a 2 bedroom, 2 bathroom house with a basement. You can say a 2 leve, 4 bedroom, 2 bathroom house!
on Mar 19, 2011 | Tools & Hardware - Others
Where to buy a s1101 replacement sewage pump
Where replacement tank for 1101 power flush system
Aug 03, 2014 | Star Water Systems PowerFlush Sewage...
Motor hums, water leaking out from under toilet,will not grind
If it is not tripping the GFCI Outlet or tripping a breaker, than more than likely the impeller is stuck. You will have to remove it to find out.
Nov 03, 2013 | Star Water Systems PowerFlush Sewage...
Basement bathroom install
you may dig two feet to find pipe then tie in with wye fitting
Mar 04, 2012 | Plumbing
Yellow Spots on Bathroom ceiling/walls after showers
You will have to paint over your new paint with a primer called BIN which will dry in about an hour. Then you can put your color coat on that. Problem solved.
Dec 04, 2009 | Home
New bathroom venting in basement bathroom.
Install a window mounted exhaust fan if you can discharge to the outside of the house surrounding atmosphere.But undercut the door of the batroom to allow air coming in into the room.Alternatively firt a door grill 600 x 150 mm size which is more expensive.THe size of the fan should be 50 to 100 l/s of air flow.
Mar 24, 2008 | Fantech Fans Exhaust Fan In-Line
Star Water Systems PowerFlush Sewage Ejector System S1101 Logo
Top Star Water Systems Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Star Water Systems Plumbing Expert? Answer questions, earn points and help others
