Question about Hunter Dryers
Bypass wattage limiter on hunter ceiling fan - Hunter Dryers
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
  • 7 Answers
SOURCE: Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Posted on Jun 27, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Do you have mod.#98480x light limiter A
This is a wattage limiter inside the the fan. If you have replaced the lamps recently, you have probably put in those with greater wattage than permitted. Replace the lamps with same as original. If it still flashes, you could remove the light limiter and wire direct.
Mar 13, 2015 | Hunter 52" Ceiling Fan With Light
How do I stop my ceiling fan light from flashing?
Make sure the wattage is correct. If it is then try a lower wattage.
Oct 03, 2014 | Hunter Dryers
Is it dengerous to bypass wattage limiter
What do mean "wattage limiter"? Do you mean a dimmer switch? If so, what do you mean by "bypass"? Your bulbs (if in USA) are rated for 110-120 volts, and use whatever wattage they say they are rated at. Wattage is the amount of 'power' consumed. By "bypassing the switch", I assume you mean direct wiring them. IF so, they will only use whatever they are rated at.
Sep 29, 2014 | Hampton Bay 24002 Ceiling Fan
Wattage limiter hunter ceiling fan
As per the Energy Policy Act of 2005, all ceiling fans manufactured or imported into the United States must utilize a light bulb wattage limiter as of January 1, 2007. This limiter limits the capacity of the fan's light kit to a maximum of 40 watts per bulb. Not very bright at all!
Put in LED lamps and save a lot of work. Go to: http://www.youtube.com/watch?v=7WeWSKNe64A it will show you how.
Oct 18, 2013 | Hunter Ceiling Fan Light Switch Control
98480x
Can you elaborate more on the damage etc and how you have a solution
May 31, 2017 | Hunter Ceiling Fan Light Switch Control
We purchased a hunter grand visita and when we turn the light on a the breaker box or the switch plate there is a delayed reaction before the light comes on whats going on?
Here is what hunter technical support says about this.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Mar 01, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Ceiling fan light flashes
There is a small part in the light kit of the fan connected to the lighting circuit. The part is relatively common to these fans and is most likely in yours as well. The sticker on the side of it shows model 98480X part number 98480-02. Clip the leads to remove this part and wire-nut the wires back together bypassing it (black/red to black and white to white). This will get your unit back to normal and the switches will still work. I spoke with Hunter and this part has nothing to do with the remote control features of the fan. It is a wattage limiter. If you attempt to put bulbs into the fan that are higher than the recommended wattage this unit steps the voltage down to prevent overheating and possible electrical issues. Removing it will not prevent the fan from functioning but you should be aware that it is in there by federal regulation requirement and without it you could risk electrical failure or fire if you put bulbs in that are too high a wattage. If you call the manufacturer to report the issue they will send you a new lighting housing for your unit which will have a new limiter in it and solve your issue as well. In my case I needed the light working so I bypassed it then requested the part. In the meantime I just made sure that the bulbs I was using were well within spec. In my case the limiter was just on the light, but depending on the model or how the wires were nutted together by your electrician if the fan was also nutted on after this device it would certainly have issues as your bulbs would now be limited to the total wattage of the bulbs and fan combined. Hope this helps all!
Dec 13, 2008 | Hampton Bay 52 In. White Redington...
Dryers Logo
143 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
