Question about Akai LCT2785TA 27 in. LCD Television
Problem ejecting the cd
The cd I loaded into the unit will not eject. the door will neither open or close
    Sergeant:
  • 274 Answers
This could be a problem if your not use to taking any thing a part. if you think you could take on the job you need to unplug the mains plug first then take screws out of case then you will see 4 small screws black ones lift the black lid off take out the CD and put it back together then try opening and closing it loads of times then stick in a another CD and see how that gos if no luck then it could be you belt is broken or your moter is stuck or had it. sorry hope i can help
Posted on Jan 03, 2008
SOURCE:
How can I eject a cd drive from an Acer Aspire e 15?
Are you asking about ejecting the drive or the CD in the drive? The drive you may or may not be able to eject. Flip over the laptop look for slides or what looks like switches under the CD. Some units may have these releases. You usually slide them to one side or another and the drive can be removed.
If you are asking about the CD, i.e.the laptop wont power up but you still have a CD/DVD in the drive you want. Usually there is a tiny hole on the drive door. It's about the same size as a paperclip diameter. Unbend the paperclip until you have about 1 inch of wire straight out at a 90 degree angle from the clip. Gently slide the wire into the hole on the drive door and give it a gentle push. The door should unlock and come open just a bit allowing you to pull the door all the way open and remove your captured CD. The gears that open and close CD's are plastic and can be stripped very easy so be gentle. Close the CD by slowly pushing the door closed.
Dec 31, 2014 | Acer Aspire Computers & Internet
CANT OPEN THE CD DOOR
Take out the complete mech, look for a small pulley wheel under the tray and turn it with your finger until it releases the disc
Apr 19, 2014 | Kenwood Audio Players & Recorders
The cd player will not open when you press the open close button
unfortunatly the mechanism is jammed up for one reason or the other reason #1 a cd is stuck inside #2 the gear just wore out and or it was forced closed by hand instead of pushing the eject/load button..you can try to gently pry this door open while pressing open/eject button that works 40% of the time..if it does not work? it can then be deemed broken out of order.
it's worth a shot trying to pry it open but beware this could either work or really destroy the door/mech/player comes down to this "do you feel lucky" sadly? that's where we're at with this one.
Mar 20, 2014 | Electro Brand Nostalgic Stereo CD Music...
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Crosley CR248 Turntable
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Open/close doesn't work
When you press Eject CD button, do you see CD display blinks as if its preparing to be ejected? If its true then eject switch is working and cd mechanism is stuck, requires service. Also check loading belt in mechanism.
And if unit shows no response on pressing CD Eject button then switch is bad, replace it.
Jun 30, 2009 | Aiwa NSX-A115 Shelf System
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Disk player door
You would need to disassemble the unit to take out both the CDs. Trying to force the disk out without opening the unit might damage it. If you are not comfortable with open it, please get someone who can actually do it for you. please revert back with the results.
Mar 22, 2007 | Bose (321GS) System
Akai LCT2785TA 27 in. LCD Television Logo
37 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
