Question about Tools & Hardware - Others
Belt/disc sander Tool line model BD46C Instruction manual. can i download one from some where? Any help greatly appreciated Thank you. Gary
  • 384 Answers
SOURCE: Tool Shop Belt sander - can't align belt tracks to thee inside
The problem is that you have not set the adjustment properly. Back off the adjustment screws,slide on the belt and center it over both rollers, addust a little at a time both screws, after belt begins to tighten up stop adjusting. Turn the power switch on for about 1 second. Is the belt tracking? Adjust as necessary. Try the power again for longer and longer periods untill belt tracks in the center of the rollers. Tighten nuts to keep adjustment screws from backing out.
Posted on Jun 12, 2009
SOURCE: I need manual for Craftsman 315.11720 belt sander
Place the front roller against a workbench or the curb and push until it locks. Remove and replace the belt, to release the locking mechanism, use a flat head screwdriver and push the roller into original position. Simple.
Posted on Jul 11, 2009
SOURCE: User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Posted on Oct 22, 2009
SOURCE: I have a Canadian tire model 55-3550-2 belt/disc
I went to a bearing/powertransmission supplier. The number on the belt was all they needed. Picked up a new belt for $6.50.
Posted on Nov 28, 2009
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Posted on Jun 16, 2010
Please help me find a free owners manual for my porter cable 352vs belt sander
The ServiceNet site has the manual for most Porter Cable power tools here: http://servicenet.portercable.com/ . The 352VS documentation is here: http://servicenet.portercable.com/Products/Detail/352VS . Look in the right hand column for the Instruction Manual; you'll see an option to download a PDF or have the manual sent by email. However, you need to look at the sander and attempt to find the Type number. This will be on the label with the model and serial number. There are 7 different belt sanders that were released with the 352VS model number. Use this number to get the details for your sander. The direct link to the manual for the Type 1 version, today, is http://servicenet.portercable.com/Products/GetDocument?docName=EnA00111.pdf&productId=55856&productType=12187&documentId=32863&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/Porter-Cable/EnA00111.pdf .
I hope this helps.
Nov 20, 2015 | Sander Tools & Hardware - Others
How to replace the sanding belt
Google the model number and "manual".
Mar 24, 2014 | Rockwell RK7866 Belt Disc Sander
My belt sander is eating away to much on the left side and it is also leaving cut lines on the floor.. does anyone have a solution or a guide to how to fix this problem? my floor sander is a "Clarke...
I would first look at the discs for uneven wear but if you want and I would recommend going to "Clarkeamericansander.com" they hae service and support and technical services who can better serve you. they also have tool free numbers listed for assistance. where I work I have called them are they are really there to help. Good Luck
Sep 23, 2010 | Clarke Floor Sander Floor Sander Orbital...
I need an owners manual for a Craftsman 6" x 9" Belt & Disc bench top electric sander. Where may I go to "download" a copy. The specs for this sander are : 6" x 48" belt at 2700 FPM ...
Go to: Searspartsdirect.com and enter the full code number minus the decimal point. That will take you to a series of drawings with parts lists. Hopefully, they still list the owner's manual. Good luck!
Aug 04, 2010 | Garden
Broken belt on Porter Cable 334 T2 palm sander
got it, go to Dewaltservicenet.com and download the instruction manual or look at it and on page 14 it gives a really great view of how to replace the belt. If I have helped you with your question would you please rate this response accordingly and thank you
Oct 12, 2009 | Porter Cable Palm Grip R.O.S. With Kit Box...
Instruction Manual needed for Vivitar model 45 light meter
Here is a link to an on-line copy of the manual you need.
http://www.butkus.org/chinon/flashes_meters/vivitar_45_lightmeter/vivitar_45_lightmeter.htm
Hope this helps.
Jeff
Jan 30, 2009 | Cameras
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
Looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Dec 26, 2008 | Tools & Hardware - Others
Wood working sander?
belt because it work realy good use ing the circle scraches the wood and the beld dos not
Sep 28, 2008 | Milwaukee Tool Milwaukee 6125 Sander Ro 5...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
