55 inch TCL LED TV makes a crackle noise whether it is on or not.
jerryg50
  • 1673 Answers
SOURCE: panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
Posted on Apr 14, 2008
  • 458 Answers
SOURCE: WHEN I TURN ON THE TV ITS MAKES A VERY LOUD CRACKLING NOISE.
If you have lost your freeview channels & your picture has been breaking up (pixelating / freezing) etc as well as crackle on the audio, then I would suspect you check your antenna, it could be your incoming signal is weak which would give you these problems.
Posted on Aug 14, 2009
SOURCE: i am unable to connect
Same issue. Samsung 55 inch 8000. Wii component cables plugged in, but it is not recognized.
Posted on Aug 08, 2010
  • 7 Answers
SOURCE: I just brought my tv in 3 days ago 55 inch led 240
THE VIZIO XVT553SV has a know problem of random power cycles and random shut offs. It is recommended you call Vizio Technical Support for a proper and permanent solution.
Toll-Free: 877.698.4946 (877 MY VIZIO) Technical Support if you don't get proper assistance at that number call the Executive Office at Phone: 949.428.2525
Posted on Jul 18, 2011
ihaque
SOURCE: Samsung 55 UN55D7000 55 3D LED TV Has started a
I have a similar issue on mine but without snD issue. This happened once before and went away but just came back
Posted on Nov 24, 2011
Crackling noise in my tv
That means the End is near ,,,sorry man , dust ,,water ,,shocked ,,(ie) falling ,,,hard hit ,,, internal damage ,,,
Mar 15, 2015 | LG Electronics 60PA6500 60-Inch 1080p...
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
Tcl tv 50" keeps shutting off
Have someone check power Capacitors. China uses cheap Capacitors in a lot of their TV's. Doesn't matter brand. Replacement is simple.
Jan 15, 2014 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
55"sharp aquos led flat sreen and its making a
Can it be heard with sound off and describe the sound a bit, buzz or high pitched sound? Not unusual for the front screen unit to make a slight buzz but I gather this is loud.
Dec 13, 2012 | Televison & Video
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
