Question about Avigo 1011584 Avigo 18 inch Scramble Mountain Bike
I am trying to get this bike to Australia any ideas how to get it shipped and around how much would it be
How do I adjust the front disc brake on the Genesis V2100 mountain bicycle, model # 52686?
adjust the cable at the brakes or and piece by turning the retainer that holds the outer cable case
May 24, 2016 | Genesis 26 Inch V2100 Dual-Suspension...
Can't find instructions on how to put the rear derailleur system back on after changing tire.
Firstly, why take off the gear mech to change tyre ? All you do is free the rear wheel, then slide it forward and unhook the chain.
Anyway, we'll need to know the make of the gear mech before we can advise on its replacement - a photo would be good, too.
Apr 17, 2016 | Avigo 1011584 Avigo 18 inch Scramble...
Need to find a new seat/replacement post for 24" Next PX 4.0 Boys Mountain Bike, Black
I am a privet bike repair shop the seat post is a 25.4 mm 9 inch log i have a used seat post in stock and a new seat in stock that will work with a next px 4.0 a had the same issue you contact me on my web site
May 08, 2015 | Next 24" PX 4.0 Boys Mountain Bike, Black
How to get pedals off
the pedals are reverse threaded. So instead of "righty tighty" it's just the opposite.
Apr 19, 2014 | Toys R Us 1001325 Avigo 20 inch Little...
Can you please provide me a list of all major bike types?
I have listed the most famous bike types: BMX Bicycle
Bicycle Moto Cross (BMX) bicycles are designed for rough off road riding and are typically single speed. People also use them for stunt riding, and you may see some fitted with stunt pegs.
Mountain Bike (MTB)
A mountain bike is designed for trail riding and downhill riding. It can also be ridden on the road. They come in many shapes and forms. Some have no suspension, whilst others have front and rear suspension. A mountain bike without rear suspension is usually called a hard tail bike.
Most MTBs use 26 inch wheels which is the standard. This size wheel is fairly strong, especially when coupled with the large off road tyres that are fitted to MTBs.
An MTB is suited for off road riding and will handle rough terrain quite easy. It is very stable on rough terrain, but is a lot slower to ride on the road when compared to a road bike. It is also suitably geared for climbing hills.
Hybrid Bicycle
Another style of bike that has a similar riding position to a mountain bike, but better road speed is a Hybrid bicycle. Hybrids are a cross between a mountain bike and a road bike. They have an upright comfortable position, road tyres, and are usually a lot lighter than a mountain bike.
Hybrid bicycles are typically used for commuting.
Touring Bicycle
A touring bicycle is designed for loaded cycle touring and has the capability to be fitted with mudguards, racks, panniers and extra water cages. They are typically fitted with wider road type tyres that are suitable for gravel riding also.
They usually come with a stronger frame and longer chainstays so that the back of your feet don't hit the rear panniers. They are usually fitted with a relaxed drop bar style handlebar. The geometry of the frame is also different and allows for much more easier steering and handling when loaded.
Expedition Bicycle
As above for touring, but usually fitted with Trekking bars and MTB gear and is designed for extreme off road conditions.
Randonneur or 'All Rounder'
A rare beast in Australia where we like to specialise. 'Randonneur' is a French term, coined to describe a bike that can do a bit of everything - you can ride with the pack or take a doddle with the kids, you can ride light or carry a load, you'd use it to visit Gran on Sunday then pick up some groceries on the way home. They are the 'family station wagon' of cycling. However, like any Jack of All Trades, they do everything well but the specialists do it better. They can carry a load but not like a heavy tourer. They are fast but heavier than a racer and with more comfortable geometry. They have wider wheels and tyres to ride on rough roads but wont handle true off road work.
Typically, they look like any other racing or flat bar road bike ... until you look at the details. Most randonneurs start life as a touring bike or hybrid, and are then modified by the owner over time to reflect how they are used.
Dec 21, 2010 | Cycling
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
Making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
Apr 04, 2010 | Huffy Alpine Men's 26-Inch Mountain Bike
Avigo 1011584 Avigo 18 inch Scramble Mountain Bike Logo
96 people viewed this question
Top Avigo 1011584 Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you an Avigo 1011584 Cycling Expert? Answer questions, earn points and help others
