Question about XO Vision XOD1742BT Car DVD Player
Xovision power i have a problem with my monitor i cant get it to power up
I bought a XoVision gx2801 at a yard sale for 5bucks, the screen turns on and says no signal. what do i connect the yellow cords to on my XOvision gx2801 go to?? could it be the yellow cords no longer...
Does the monitor have a dvd player built in to it? Are you trying to play video's? Or is it just a monitor and your trying to get a tv signal? I believe that the two yellow cords you are talking about either go to the antenna unit to get a signal or connect to a dvd player or another media source to play on the screen. What do you have connected to it? Please go to your original question and click on reply or comment to answer my questions and I will try and help you with this.
Apr 22, 2011 | Vision XO- GX2801 8'' Wide Flip LCD...
Distorted image only when vehicle is running
Get Snap-On Ferrite Chokes and place them on the Audio and Power lines leading to the monitor.
Jan 30, 2010 | XO Vision Car Audio & Video
I have run on in a vauxhall vectra 1996 n reg
If you mean pre ignition,it is normally caused by to weak a mixture, ie,a leak on inlet manifold or vacuum pipe or wrong spark plugs, or overheating
Jan 25, 2009 | XO Vision GX1211 XOVision 12" Roof Mount...
Not able to do fm transmittal
if the headsets work the fm transmitter may already be working. unless they are using an ir signal. you can test this by blocking the the ir or (infrared) led's on the lcd and the dvd player , if the headsets still work than its probably being sent via fm signal. turn your head unit on to fm andstart at 87.1mhz and work your way up to 89.9mhz in .1mhz intervals fm transmiters are usualy some where in that frequency.hope that helps
Dec 01, 2008 | XO Vision XO-141FM 14.1 in. Car Monitor
Toyota estima emina 92
if water is in the oil, it is likely you have a blown head gasket. does your car have white smoke at the tailpipe?
Feb 20, 2008 | XO Vision GX1211 XOVision 12" Roof Mount...
XOvision DVD/ Tv Tuner
the brake wire is connected to your hand brake to stop you watching tv while you r driving its a safty thing as you have not connected it it might be why you cannt watch tv hope this is of some help
Dec 27, 2007 | XO Vision GX1211 XOVision 12" Roof Mount...
Xovision monitor
To what car?
Black wire to ground.
Red wire to +12VDC.
Yellow cable to input of Yellow Input's radio.
atdlee@netzero.com
Dec 21, 2007 | XO Vision 12.1 Flip-Down Monitor w IR"
Car stereo tv tuner
go to xovision.com download product manual... that is what i had to do.
May 26, 2007 | XO Vision MD068 6.8 in. Car Monitor
XO Vision XOD1742BT Car DVD Player Logo
16 people viewed this question
Top XO Vision Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
mega_mind
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
