Question about KitchenAid KUDS40CVSS Builtin Dishwasher
Thermal fuse fuse location of kuds40cvss 3
Daewoo dryer (thermal fuse)
-Most dryer's thermal fuse are locate on the back (Inside).
-Disconnect main power before remove the back panel cover off.
-Usually there are 3 thermals. (2 at heater element, 1 at exhausted
vent)
Good Luck
Mai
Dec 20, 2013 | Dryers
Where is thermal fuse
If your Kenmore dryer has stopped producing heat, chances are the problem lies with the dryer's thermal fuse. A fire-prevention safety device, the thermal fuse is designed to disrupt the flow of electricity to the dryer's heating mechanisms if the dryer temperature reaches a predetermined maximum. Once activated, the thermal fuse must be replaced to restore the heat to your dryer. In Kenmore brand residential dryers, the thermal fuse will be located in one of two places.
Instructions
Front Panel Access
1 Unplug your Kenmore dryer from its power source. Make sure that the appliance is unplugged before proceeding.
2 Use a flathead screwdriver or putty knife to remove the dryer's bottom service panel, sometimes called the toe panel. Slide the screwdriver or putty knife along the top of the toe panel until you've located the toe panel clips. The clips are usually located about four inches in from either side of the service panel. Push down on the toe clips with the screwdriver or putty knife to release. Remove the panel and set it aside.
3 Locate the thermal fuse on your Kenmore dryer. Look for the thermal fuse directly above the dryer's motor; it looks like a white strip with two wires, and is usually mounted off to one side. See Resources for a diagram of thermal components.
Rear Access
4 Disconnect the Kenmore dryer from its power source while locating the thermal fuse.
5 Move the dryer away from the wall so that you can access the back of the appliance.
6 Use a screwdriver to remove the dryer's back panel. Set the panel and loose screws aside until you are ready to replace them.
7 Locate your Kenmore dryer's thermal fuse just above the exhaust port. The thermal fuse looks like a white strip with two connected wires.
Tips & Warnings
Clogged exhaust ports are a common cause of thermal fuse failure. While you've got your Kenmore dryer in pieces, clean out the exhaust ducts to keep it functioning at its best.
Take all proper safety precautions when working with electrical appliances. Make sure that your Kenmore dryer is unplugged before attempting to service it.
Check this link ,if you use Whirlpool Dryers:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/thermalfuse-dryer-Whirlpool-29inch-electric.html
Thanks
Apr 01, 2012 | Dryers
Where are fuses located on Whirlpool electric dryer?
Check the internal thermal fuse, which is located within the back panel. The fuse is about an inch long and oval-shaped.
If your dryer is not getting hot, the thermal fuse may be blown. Instead of calling an expensive repairman, you can replace this simple part yourself in less than an hour. Make sure you purchase the correct replacement fuse for your make and model of dryer. Your owner's manual should have a list of compatible part numbers. You may also be able to order a replacement directly from your dryer manufacturer's website.
Things You'll Need
  • Hex nut screwdriver
  • Replacement thermal fuse
    • 1 Disconnect the dryer from the electrical outlet. Remove the dryer vent from the back of the dryer by loosening the retaining screw on the clamp attaching the vent to the dryer's exhaust port and sliding the vent off of the port.
    • 2 Remove the hex nuts holding the dryer's rear panel in place. Slide the panel off to the side of the dryer. Locate the thermal fuse on the heating element housing on the right side of the dryer. The fuse is an oval-shaped part located near the top of the housing.
    • 3 Slide the thermal fuse wires off of the contact terminals on the fuse. Remove the hex nut holding the fuse in place and remove the old fuse.
    • 4 Place a new fuse on the housing and replace the hex nut. Reconnect the thermal fuse wires. Replace the dryer's rear panel and plug the dryer back into the electrical outlet.
Jun 12, 2011 | Whirlpool LER8648P Electric Dryer
Not heating
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
Also check my tip on thermal fuse locations
Jan 09, 2011 | Whirlpool Dryers
My dryer will not produce any heat ? it is only air drying. Is there an element I need to replace or a fuse ?
Jan 08, 2011 | Whirlpool LER4634J Electric Dryer
Dishwasher not starting
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 03, 2010 | Whirlpool 24 in. DU930PWP Built-in...
Need help locating fuse or thermal cut out on Amana Gas Dryer
ther thermal fuses and all thermos are locate dbehind the lower acess panel.. youll need to check for continuity throuhgt the thermostats, particularly the one atop the flame can...
Mar 15, 2009 | Amana NDG7800AW Gas Dryer
I have a whirlpool dryer. Model LER8648LW. Where is located the thermal fuse?
Hi and welcome to FixYA!
That thermal fuse will be located in the blower duct in the back of the machine. Take the back off the machine, look for what will probably light-blue colored wires attached to a white plastic oblong thermal fuse. For your model that part is #
3392519
If this is helpful info please rate me!
Dec 14, 2008 | Whirlpool LEQ9858P Electric Dryer
Thermal fuse
hi. thanks for the question. the thermal fuse is located in the dryer, on the air duct, small piece with 2 wires to it. replace . also clean venting, and inside the dryer.thanks the appliance doc
Oct 05, 2008 | Dryers
Open Questions:
See all KitchenAid KUDS40CVSS Builtin Dishwasher Questions
KitchenAid KUDS40CVSS Builtin Dishwasher Logo
22 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
