Question about COP CB25NV-IR Color Cam 1/3 Sony CCD 420Lines, DC/Video Auto Iris Sup
Records sound but no picture
When you hook the cam up to a tv for playback, does it have video?
Jul 25, 2008 | Sony Handycam CCD-TRV37 Camcorder
1/3" SONY ir camera car-b3110hq. dc12v pal. Black horizontal lines scrolling up the screen. About an inch wide. Camera still working though. Intermittant fault seems to come back when the auto focus...
It seems that the power adapter in for for you country. It may be a import. Normally adapters can handle 50/60Hz but not good adapters or false adapters or adapters made for certain region are unable to handle both frequencies. This is normally the cause of the stripes you are seeing.
Cheers
TeaCii
If you own website, add live support almost free
Let real security guard watch your cam for $1/day
Jan 15, 2010 | Sony 1/3 inch CCD infra red CCTV Security...
My lcd and view finder are unable to show subject
The problem you are having is called a "stuck iris" Inside the lens are two thin plastic sheets that slide over one another that limit the amount of light that comes into the lens. In some Sony camcorders, the motor or "actuator" that drives the iris, or moves the two sheets which are the iris opened and closed. The actuators sometimes leak oil onto the plastic sheets causing them to stick, so the light coming into the lens is stuck at one level. Some technicians will recommend lens replacement (expensive) but many times the iris assembly can be removed from the lens and cleaned. Try to find a service shop that will clean the iris rather than replacing the lens.
Nov 11, 2008 | Sony Handycam CCD-TRV98 Camcorder
Play back is in black and white
Set your TV in auto mode or according with your CAM system PAL or NTSC and some of the CAM you can set for AV out in PAL or NTSC system
Cheers
Nov 03, 2008 | Sony Handycam CCD-TRV308 Camcorder
Black scrren in record mode
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Jul 24, 2008 | Sony Handycam CCD-TRV68 Camcorder
Black lcd screeen on my sony handycam
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company....
Oct 19, 2007 | Sony Handycam CCD-TRV328 Camcorder
Does not record video
Oct 02, 2007 | Sony Handycam CCD-TRV608 Camcorder
No image (LCD and viewfinder)
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company...:-)
Aug 15, 2007 | Sony Handycam DCR-PC330E Mini DV Digital...
COP CB25NV-IR Color Cam 1/3 Sony CCD 420Lines, DC/Video Auto Iris Sup Logo
23 people viewed this question
Top COP Video Cameras Experts
Are you a COP Video Camera Expert? Answer questions, earn points and help others
