Whirlpool, #WTW4800XQ2, error msg says lid lock, so replaced it but machine want start?
SOURCE: Washing machine powers up, but dosen't continue to
I had to replace the main circuit board. This solved the problem.
Thanks for the help.
Posted on Sep 18, 2009
caroldon
  • 17129 Answers
SOURCE: brand new Whirlpool WTW4800XQ out
Before you attempt to do anything please check if the drum lock is removed, check the power plug, connect the water line inlet. and finally check the settings of the program.
Read through the manual and DO NOT ATTEMPT TO DO ANY REPAIR AS BEING A NEW SET you have warranty.
Call your dealer if the set hums even after the initial checks were done.
Posted on Aug 04, 2011
dyronwebb
  • 220 Answers
SOURCE: Whirlpool cabrio washer doesn't start, Can I fix this by myself?
If you replaced the lid lock then you know how to get the top of the cabinet up lift the top up there should be a technical sheet in a plastic packet on the front panel it will tell you how to run a diagnostic if not there turn machine off press and hold any button except power/cancel for 3 seconds release 3 seconds repeat until 88 appears after that any fault codes should appear I have only had to replace a control twice on these units I am curious to see if you get an F50 or F51 code this is the most common when this machine first starts the lid should lock a short rotation of the basket lid unlocks then locks a short fill then rotation of the basket let me know what you find could be the control but I would like to eliminate the rotor and RPS sensor
Posted on Jan 18, 2015
DIESELMUDDER
  • 2760 Answers
SOURCE: My Whirlpool Cabrio washer wtw555oxwo turns on, lid locks, then the lid lock light starts flashing and the machine does nothing. Just replaced the lid lock, but nothing has changed. Any suggestions?
adjust the lid lock switch?? seems to me that lid lock mech is not moving far enough to properly be sensed by switch
if machine is over 8 months old id suspect rust in lock arm as cause
Posted on Jul 22, 2015
Lid lock error
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 09, 2016 | Whirlpool WTW8200YW 4.6 cu ft Cabrio White...
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Jul 22, 2015 | Whirlpool Washing Machines
Why does my WWtw4800xq2 start normally BUT gets stuck on rinse?
What you are describing sounds like an actuator motor. The part is http://www.repairclinic.com/PartDetail/Shift-Actuator/W10006355/1719787?modelNumber=WTW4800XQ2?RCAID=1000057 You need to lay the machine down after draining it by hand and then remove the part and replace it.
Apr 30, 2015 | Washing Machines
Jan 18, 2015 | Whirlpool WTW6400SW Cabrio Washer
My washer won't wash it just keeps locking and
I have the Whirlpool WTW4800xq2 and this happened after only 5 months of usage. It was the control board (ie brain) of the machine. Had to be replaced. thank goodness it was under 1 yr warranty. i hate this washer. it doesnt wash clothes cleanly at all. good luck.
Jan 29, 2013 | Washing Machines
I have a top load machine which shows LE error code despite lid is closed properly. This continues for half an hour then machine starts working again but the error resumes after every two minutes. Plz help
'LE' stands for Lock/Lid Error. There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
