Question about Duke Ovens
Duke oven m/n e101-e wont stay at set temp - Duke Ovens
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: the oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Posted on Mar 03, 2010
  • 106 Answers
SOURCE: hi,
Check that the elements are high quality, dont use cheap elements, also replace all the elements and all are working, do not leave the door open while heating for along time. Do not power cold water on them while hot to clean let them cool down gradually.make sure the termina conection to are not loose during replacement. swicth off when you dont need to use for a long
Posted on Jul 29, 2010
  • 223 Answers
SOURCE: I have a duke e101-g
Generally, when you wish to change the fuel for a gas appliance all you have to do is change the orifice. Most appliance dealers will be happy to order a LP orifice for your oven for you.
lp
Posted on Dec 30, 2010
Why would a duke E101-G will sometimes work fine and sometimes dont I replaced the thermostat but it is doing the same thing
When you have a high end oven like this you will find that the manufacture stands behind it. try to find a 1800 number and talk to parts. they will probably want you to talk to an approve alliance repair person but if you ask the right questions and listen between the lines you might find out what you need to know to fix it.
Dec 10, 2014 | Duke Ovens
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 | Ovens
Why would a duke's manufacturing co oven model E102-g stop heating ?
An erratic thermostat, heating element, or both.
Jul 28, 2014 | Duke Ovens
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
I have a duke e101-g oven and I want to convert it to propane what should I get?
lp
Dec 30, 2010 | Duke E101-G Gas Single Oven
Hi, the elements on my duke e101-e 240v single phase convection oven keep going out every 3 to six months...is there any other reason why they would go out so often?
Jul 29, 2010 | Duke 59-E4Z Electric Single Oven
I have a defective flame sensor on a duke oven, I need to know the best way to remove it to replace with a new one. It does not appeear there is enough room inside to access it.
it does require removal of entire burner assembly. which is not all that hard to do but a bit time consuming. fittings for 2 burners and pilot must be disconnected and 3 screws on front of burner assembly. unit will then pull right out allowing access to flame sensor bulb. hope this helps!
Apr 22, 2010 | Duke E101-G Gas Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
32 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a Duke Oven Expert? Answer questions, earn points and help others
