Question about Toshiba TDP-T45U DLP Projector
My toshiba dlp projector turns on then turn off with fan indicator showing red
SOURCE: Toshiba TDP-T90 projector, lamp
I have the same problem. The lamp cover has a tab that sticks up about 1/2 inch. When you close the lamp cover the tab presses on a wire that allows power to the lamp. You can hear a 'click' as you close the cover slowly. My tab kept bending over preventing it from depressing the wire. I've straightened it several times to where now it broke off to where it wouldn't work at all.
I fixed the problem by clipping off the tab, inserting it in the bulb case to press the wire and taped the tab in place.
Posted on Dec 02, 2008
projdoc
  • 2237 Answers
SOURCE: Describe your Toshiba TDP-S35 DLP Projector
this model is a dlp, not an lcd. reset the settings to factory default. if that doesn't help, replace the colorwheel.
Posted on Nov 11, 2009
SOURCE: toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Posted on Nov 12, 2009
  • 6 Answers
SOURCE: I have a Toshiba TLP 260 Multimedia Projector
If all the fans are running and you are sure, than it sounds like you have a bad main control board. Double check that all the fans are running. If so you will need to replace the main controller, this is the board that the fans are plugged into.
Thanks the Projector Guy
Posted on Apr 21, 2010
  • 22 Answers
SOURCE: I plugged in my toshiba DLP projector one day and I heard a pop
Sounds like a blown capacitor...they age...leak..and bulge..
and then blow out...
Check (visually) all the capacitors on your power supply board...
if they are fat, bulging or leaking...they should be replaced.
Posted on Jul 21, 2010
Vivitek 1080 power blinks 6 times the flashes red 1 time
That indicates an error in one of the cooling fans, Fan1 (sorry, I cannot recall the physical location of Fan 1). The problem may be that something has jammed the fan and stopped it from rotating. Carefully inspect each cooling fan in turn and ensure they are free to rotate. If they all are, and the connectors are firmly plugged in to the main board, then Fan1 will have to be replaced
Apr 05, 2014 | Vivitek H1080FD DLP Projector - 1800...
Acer x 1130 dlp projector not lighting but showing red light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
any questions, feel free to contact me
have a nice day!
Sep 25, 2012 | Acer X1130P 3D Ready DLP Projector...
Toshiba xp2 projector overheating
Better late than never for any other XP2 owners out there. I've gone through 1 lamp so far with very good results. The key to overheating is cleaning the fan out, i.e. it sucks in a lot of dust particles over time which accumulate on the fan blade and in the vents blocking good airflow. Take a good strong vacuum hose to every vent, then again right when you turn it on. This will get the fan up to speed quickly and assist with removing more dust internally. Eventually, you'll need to open the projector up and clean internally (carefully), but doing the above maintenance will prolong its life and extend the lamp too!
Feb 22, 2012 | Toshiba TDP XP2 DLP Projector
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Mitsubushi DLP Projector Problem
I am having the same problem with mine.
Jun 23, 2009 | Mitsubishi HD1000U DLP Projector
Toshiba projector switching itself off
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
Toshiba TDP-T45U DLP Projector Logo
24 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
