Asus x52s the screen is a gradient grey. Colour. Windows vista still loads as I can hear the logon tone. Would this be the graphic card? Thanks pauline
    Sergeant:
    Champion:
  • 266 Answers
No, its a common issue in vista, it's the drivers, check to see if there are new ones, or you can also "roll back" the drivers if it did a update.
Posted on Oct 18, 2013
5 Suggested Answers
Morkai_bde
SOURCE: psu and graphic card
Starting from top to bottom:
Yes, your PSU is able to run the card, depending on what other hardware you have also makes a deference in the power required to be supplied by the PSU
The 7950GT 512MB needs a minimum of a 350w PSU, but NVIDIA recommends a 400w or higher for optimal performance of the card
On the problems side:
The green and purple stripes can be created by a number of problems, but the most common is faulty hardware
The screen being pixilated can be 3 things, a wrong driver or no driver at all, screen resolution to low for the screen you are using, or yet again, faulty hardware whereas the first two is more likely
The system not being able to boot into windows could be related to the driver not being installed and/or the card not getting enough power, it can also be related yet again to a faulty card, but it being a Driver is this case most likely in this case, and since you can boot into save mode, see if you can see any driver files left over by your X300, it isn’t uncommon for files to say behind after the program or component has been uninstalled
The devise being stuck in an infinite loop can and most likely be caused by the drivers as well, since windows has a default *no extras* driver built into the system, is can cause the problem because the instructions that the card uses are not included in this deavult driver
Save mode does not stably support any higher resolution than 640 x 480 (up to 800 x 600 with SP2 installed) and can/will cause problems if set to any higher
Weird color pattern can be cause by a few things as well, the problem could be with your screen not displaying the color properly, it could be a faulty driver giving wrong color information to the card, or it could be the card itself, with the driver not being installed seems the be the culprit in this case
Recommendations:
Test the card in another computer or multiple other computers (if able) and see if the problem arises with the other one as well, that way it can be determined if the card is working properly, try a bigger PSU, the card might not be getting enough power the root of all the above problems, if possible, try and download the latest drivers for your card, preferably the WHQL certified forceware driver and try and install id under Save mode(it is possible) while in save mode, see if any files are left from the previous drivers and remove them, reboot and see if problem persists, A windows repair might also be needed in some cases, if there are up-to-date backups of your pc it is a good way to sort out certain windows booting problems, or take the card back to the place it was bought and let it be tested under certain controlled conditions if it comes to that a format and clean install of windows might be needed, but that is a last-resort fix and should be avoided if possible
Posted on Oct 11, 2007
  • 375 Answers
SOURCE: blank screen after boot up
Remove the card, plug into your built-in card. Start your PC in safe mode. Uninstall all ATI software and delete the card from Device Manager. Restart. Reinstall the ATI drivers. Power down. Install the card and connect your monitor to it. The OS will find the card in default mode - let it. Restart. When it comes back up, you will be able to select the full range of operating modes.
BACK UP :)
Posted on Jun 29, 2009
proton77
  • 1183 Answers
SOURCE: Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Posted on Aug 28, 2009
Testimonial: "I thought I had tried everything, but Proton taught me something new, and only a minute or two after I posted my problem! Works great now. Thanks!"
  • 11800 Answers
SOURCE: windows 7 drivers for my
This video card is not compatible with Windows 7 - it doesn't meets the minimum requirements: it's not Dx9.2 capable, only Dx8.0.
You will need to buy a new video card.
Posted on May 08, 2011
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Asus G1 vga problem
hometokota I am having the same problem and I have tried restoring vista and everything to no avail. Did you find any solutions to the problem?
Jun 29, 2009 | ASUS G1 Notebook
My Asus notebook series X52S is not booting up, it is turning on, and saying that there is a critical error and then requests whether i start windowns normally of start up in safe mode. I request safe...
There's a selection on that screen for "last known good configuration" - try that, sometimes a driver that has been recently installed can cause a machine to crash on boot. If that doesn't help, you can attempt to boot from the installation CD that came with the computer and repair the system. Boot from the install CD, select ENTER in order to continue with the setup program (trust me, we're not going to do a full setup, but you have to choose the first option here...). More files will load from the CD - the next screen should be the repair screen - it should say "To repair the selected Windows XP installation, press R" - press R, and the repair should begin. Reboot after it's done.
Please rate this answer if it's helped you out, thanks!!
May 08, 2009 | ASUS Computers & Internet
Ok my graphics card is a 128mb ATI Radeon x1300,
You may need to reset your screen to the new card - or it could be a faulty graphics card.
Apr 28, 2009 | HIS (H130HMF128E1) ATI RADEON X1300, (128...
When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Mar 28, 2009 | ViewSonic VX2035WM LCD Monitor
Graphic issue
It sounds like the refrsh rate set in Windows is too high for your monitor, try going into safe mode and setting the refresh rate to 60Hz.
Jun 26, 2008 | GE Asus V9400 /TD GeForce MX4000 64MB DDR...
Bad startup display, death upon sleeping, app opening trouble and scroll-display problems.
I have an old comp and my is working good.
Thanks for updating each time and to cleaning all systems each day.
Try clean your Disk with clean up disk utility
you should go on all programs, find- accessories,disk clean up,
after you done that,do the disk de-fragment and clear all programs what you not using at all( be carefully with that) to don't clean something useful.
after you done all that try reinstall the vista or reset on factory settings by going in bios screen (it appears when you switching on before log in-in and see what you have a disable.Click on that to enabled and boot up again.
Jun 12, 2008 | Computers & Internet
Need drivers for vista
You can download it to http://support.asus.com. Search the model of the motherboard and then download it.
^_^
Jan 24, 2008 | ASUS K8V-MX Motherboard
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
Computers & Internet Logo
David Payne
David Payne
