Question about Moultrie D55 Digital Camera
My camera isn't working correctly. After inserting the SD card in my Moultrie D55. The count on the front screen doesn't seem to work correctly it shows 0000/0000 where it should show 0000/3500 or whatever depending on the size of the SD. Any solutions would be appreciated. I have tried multiple SD and HCSD cards.
SOURCE: sd locking
I had this problem also. To solve the problem I blew into the slot where the card goes and it then read the card. If dirt gets into the port it causes the sd card to lock. You may have to use a pressurized can of eletronic spray to clean the port.
It worked for me.
Posted on Mar 04, 2009
  • 3 Answers
SOURCE: camera screen said SD card is locked when I installed an SD card
#1) On my camera if there was a picture that got stored in the internal memory it would not reconize the sd card nor store the pictures on the sd card. I would have to take the sd card out and delete the pictures in the internal memory and then reinsert the sd card.
#2) Some how or other the files that were on the sd card would get scrambled on the sd card when I would try to erase them. I would have to reformat the sd card back to a "fat" format before it would work again.
Posted on Jul 28, 2009
  • 296 Answers
SOURCE: moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
Posted on Feb 17, 2010
  • 296 Answers
SOURCE: moultrie d40 locks up when I put the sd card in???
make sure card lock switch is forward toward contact strips fully.
Posted on Feb 20, 2010
  • 296 Answers
SOURCE: Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Posted on Mar 06, 2010
There is no button on front to release battery compartment
No, it is on the bottom
Page 3
Slide the UNLOCK switch on the bottom of Camera and use the knob to pull the slide-out
Battery Tray. Install eight (8) AA size alkaline or lithium batteries with polarities as
indicated in the Battery Tray. Re-install the Battery Tray and insert your SD card.
We recommend that you format the SD card inside the camera before taking pictures
http://images.ebsco.com/pob/moultrie/catalog/m-990i_manual-english_web.pdf http://images.ebsco.com/pob/moultrie/catalog/m-990i_manual-english_web.pdf
May 08, 2016 | Moultrie Game Spy M-990i
SD error show on the screen
SD card it the memory card you should insert. Fine a not to expensive on on the net, and order one.
Sep 02, 2014 | Moultrie Game Spy M-100 Mini 6.0 Megapixel...
Count down timer
Do a hard reset, turn camera off, take out battery's and sd card out. once you have everything out push your on/off button for about 5 sec. then put only battery's back it should say no card. Once it says that put sandisk sdhc nothing higher than a class 4 sd card, which is the speed of card not the size. If still not working call Moultire 8006533334 option 1 and 1 again for a live person to help you.
Dec 28, 2013 | Moultrie Feeders Lx30ir Game Spy Camera
MOULTRIE A-5 DISPLAYS "FULL" WHEN EMPTY/NEW SD CARD INSERTED
I just fixed this problem on my new A-5. I had to take out the SD card, put it in my card reader and reformat the card on my computer. I just put it back in my A-5 trail camera and now it works and is counting down like it's supposed to.
Nov 03, 2013 | Moultrie A-5 Game Camera
When sd card inserted say FULL
Camera says no sd card card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 24, 2013 | Moultrie D55 Ir Game Spy Mfhdgsd55ir D55ir
I have a moultrie cam viewer. It views pics off sd cards for my moultrie game cams. (I have 2 cams both with 16g sd cards in them m-80 xt, m-80 blk) it has worked fine for about 7 months. But now it just...
Try the cards in another camera. If you get good images to show, then the problem is in the cameras. If not, then the problem is in the reader. See whether some dirt is in the slot interfering with the contacts.
Oct 19, 2013 | Cameras
Shows card lock
Jan 24, 2013 | Moultrie D55 Digital Camera
I just buoght a d55 camera and loaded brand new energizer batteries and i get the message no sd card card protected. I have tried 3 different cards with the same results what needs to be done?
Your sd slot is damaged, You have no other laternative then visit a repair shop
I assume that you have made sure the toggle on the sd cards are not on save protect mode!
good luck
rene
Thumbs up if helped
May 28, 2011 | Moultrie Cameras
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
Moultrie D55 Digital Camera Logo
42 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
