Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Panasonic THL42ET5A HDMI link keeps failing andI have replace the HDMI cable 3 times now with different and dearer cables but still the same problem.
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Posted on Oct 03, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-46PZ85U Plasma TV
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Posted on Jan 27, 2010
SOURCE: panasonic th-50pz80 10 flashing blinking red lights
The way to solve the problem with the TH-50PZ80U blinking light problem is to not buy Panasonic Products. I have had my TV about 21 months and it has started with the blinking light problem, just out of warranty. Panasonic is aware of this problem and refuses to do recall or fix the tv unless you are within the warranty or have bought the extended warranty. Legally they are within their rights, but I am also within my rights to air my complaint and inform others of this below par product. Who wants a TV that they have to unplug for a while and pug it in again for it to work. I want to push the power button and it come's on. I will never purchase another PANASONIC PRODUCT.
Posted on Oct 25, 2010
  • 5185 Answers
SOURCE: How do I connect my
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Posted on Dec 26, 2010
SOURCE: Panasonic Viera Link stop working
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Posted on Jan 25, 2011
Panasonic TC-P54Z1 flashing image
Please remove all HDMI cables from the TV and test a different power outlet. If the problem persists then we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 21, 2014 | Panasonic VIERA TC-P54Z1 54 in. Plasma TV
No picture on my Panasonic TV
Please unplug all HDMI cables from the TV and test a different electrical outlet. If the problem persists, please use the below link to locate an authorized service center in your area.
Where to Service Panasonic Products
Mar 13, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
Sony bravia troubleshooting
Several possibilities here. First thing I'd try is replacing the HDMI cable. (They definitely do go bad). Second possibility is a problem with the cable box. HDMI outputs on these can fail too. If you have a set of "Component Video" cables (Pr/Py/Pb) try hooking up using those (you'll have to choose a different input on the Bravia). Good luck!
Jan 26, 2014 | Televison & Video
Panasonic DMR - HW100ebk.......... with both coax
So you have looped the coaxial through the Panasonic to the TV and have a HDMI from the Panasonic to the TV, right. When you turn on the DMR select the appropriate HDMI connection with the TV remote and you will be OK.
Oct 11, 2013 | Televison & Video
I have a panasonic TC-P50ST30 and viera link will not work with my charter HD DVR cable box. I have a HDMI cable connecting them.What can I do?
Unfortunately, your charter HD DVR cable box is not a Viera link device that is compatible with the TC-P50ST30. Viera Link only works to control Panasonic HDAVI devices that are Viera Link ready (and that use the same Viera link coding) when using the HDMI cable. Thus some Viera link devices of different generations will not work with the same Viera link remote.
The manual for the TC-P50ST30 is available here: http://service.us.panasonic.com/OPERMANPDF/TCP42ST30.PDF . See page 32 for details on the Viera link controls.
I wish that I had better news for you. However, you will need to use separate remotes for your cable box and the TV.
Oct 21, 2011 | Televison & Video
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
I have a Panasonic Model TC-p42X1 TV hooked up to a Panasonic SC-PT480 Home Theater system by an HDMI cable from HDMI 1 on TV to HDMI on Theater unit. System setup test okay for speaker sound connections...
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Feb 03, 2011 | Panasonic SCPT480 Theater System
Everytime I use hdmi the colours are mostly green
I have a panasonic th42pa 60a SD plasma and I get the same problem WHEN USING CERTAIN HDMI cables. I had a connexa brand with my samsung stb that i got with the TV and I had no problems., but i had to replace that because one of the ends "frayed" when it was accidently yanked out of the tv socket. A high quality monster cable did the same green screen you describe. The cheapest "Crest" from Big W that did HDMI standard 1b worked fine, but a Rank Arena from Target did not. So buy the cheapest HDMI 1b cable you can, the picture quality and sound is the same as the more expensive stuff. BTW I tried a HDMI 3 way splitter as well and it did the same green screen thing, but it worked on a later model panasonic plasma. I think it is Pana's poor HDMI implementation.
Dec 05, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
