Question about Pioneer VSX-819H-K A/V Receiver
My pioneer receiver vsx-9700s has no sound when hooked up to the speakers. I believe a fuse is blown, what should I do?
SOURCE: pioneer VSX-D503S receiver-no sound coming
it might need to be rregrounded
Posted on May 27, 2008
SOURCE: receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Posted on Dec 31, 2008
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
Connect pioneer vsx-9700s receiver to tech.equalizer??
If there is no rca connection on the back labeled something like "external processor" then it could probably go through a tape loop. At least that's the way it used to be done last millenia. ;)
Jan 18, 2013 | Bose 901 VI Main / Stereo Speaker
I hooked up a Niles speaker switcher to my pioneer vsx 521 k receiver.I tested it and immediately there was a smell and the receiver powered off . It won't come back on, is it a fuse or have I rui
The audio outputs have been fried, plus the main fuse blown. The power transformer will need to be checked for a open primary, I suggest you get a estimate first. My feeling is that it will be expensive.
Apr 07, 2012 | Pioneer Audio Players & Recorders
Pioneer VSX-9700S Audio/Video Receiver powers on then shuts off
The Pioneer 9700s is a very good sounding unit, if you are talking in home threater space, but your problem sound like the power amplifer section is giving out too HIGH DC voltage therefore ripping the protection circuit. In these newer home threater ammplifers, there are not dc offset voltage adjustment on the circuit brd. All is done by negative feed back. Sorry you ar eout of luck I don,t hinkit is worth fixing. They are not as well make as the older Sa7500, and Sa9800 amplifers of old. There is a good chance that aftera few month something else will go on them. That is why they are so cheap on Ebay, these thraeter receivers.
Apr 18, 2009 | Pioneer Audio Players & Recorders
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
SPEAKER CONNECTION
problem with connection
Jan 07, 2008 | Audio Players & Recorders
PIONEER VSX-9700S
Speakers must be selected on the front panel of the rcver, and tape ll monitor must be "off", or at least have an outboard processor attached to the tape ll loop. "A" or "B" doesn't matter, but one must be selected to hear program material. If all connections are correct and it still won't work, consider that the output stage has failed....accordianman
Dec 15, 2007 | Audio Players & Recorders
Pioneer VSX-819H-K A/V Receiver Logo
167 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
