Question about Magellan GPS
Gps my magellan blazer 12 continues to show the correct time and date buttracks satellites without picking anu up. Any ideas.
  • climb101 Dec 11, 2007
    Magellan Blazer 12 all works fine but will not pickup satellites
    relaced batteries corrected time etc.cant find a masrer reset if any in the manual. any suggestions other than paperweight ?
SOURCE: Magellan GPS 310
to reset the unit hold down the right arrow while turning it on this fixed mine!
Posted on Aug 21, 2006
SOURCE: My 700 has no GPS
I fixed this problem by opening the options menu, selecting the diagnostics button, then the initialize button. The gps began to look for satellites again and after several minutes began working as normal.
Posted on Dec 18, 2007
SOURCE: Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Posted on Jan 30, 2008
SOURCE: Garmin GPSMAP 60CS displays wrong date
mou exoun dvsei ena gps to opoio mesa einai ola sbismena.
prospathw na tou perasw ena ellhniko xarth alla den mporw...
xreiazomai help.......
Posted on Feb 03, 2009
RPFinney
  • 385 Answers
SOURCE: 305 Not Picking up satellite signal
Visit the link below to update the software,
Here
Serial to usb connector needed like this Here
Should be good after that.
Regards.
Posted on Apr 16, 2009
On my Magellan 2000 GPS I'm am try to rreset the date how do I do this?
The GPS gets date and time information from the satellites so automatic.
May 24, 2017 | I'm Watches
Magellan gps 315 will not connect to satellites
i have the same problem too, anyone has any idea. please share with us.
Dec 01, 2011 | Magellan GPS 310 GPS Receiver
Hi I have a Magellan 320 that I have owned for 7 yrs. Due to the purchase of a chart plotter I have not used the 320 for about 2/3 years. Having switched it on this week the unit failed to gain a fix to...
I believe you have to input your location lat & long so that it knows basically where it is so that it can decide which sat's to use. Hope this may help.
NOW - CAN YOU HELP ME?
I have bought a 2nd hand 320 and want to upgrade to software V 3.15
I see you've done this with yours - can you tell me how to do it and send the s/w, please? Regards, Ron. Kerikeri NZ
Jan 18, 2011 | Magellan 12, 310, 315, 320
Cant set time on magellan trton 400 gps
Go to MENU>>VIEW>>SETTINGS .. Go down the menu until you reveal more choices. Pick Date and Time and make your changes.
Feb 23, 2010 | Magellan Triton 400 Handheld GPS Receiver
I also have a Magellan Triton 300 and I can not change it to my time zone.. how can I change it?
From the user manual at http://www.magellangps.com/assets/manuals/MagellanTriton_300_400_500_UserManual.pdf
it says:
Setting the Time Zone
The time and date information will be computed from information from the GPS satellites so there is
no requirement for you to input any time or date information. However, to make the time accurate
for your location you must select the correct time zone.
1. From the Map screen press MENU.
2. Select View.
3. Select Settings.
4. Scroll down and select Date & Time.
5. Select the Time Zone field.
Press button
momentarily
Fundamentals
5
6. From the drop-down menu, select your current time zone. (Time zones are not changed
automatically when travelling. If you travel to an area with a different time zone, you will
need to change it here for accurate time information.)
7. Repeat the process for the Daylight Savings field.
8. Press ESC when done.
Jan 02, 2010 | Magellan Triton 300 Handheld GPS Receiver
My Magellan Triton 500 does not display the correct date or time. Can you help?
Assuming that you have the latest firmware installed. Do a MENU>>VIEW>>SETTINGS and then using the down arrow to scroll down. The Date and time and language and power settings are out of sight. scrool down and you will see date and time.
Dec 03, 2009 | Magellan Triton 500 Handheld GPS Receiver
Magellan roadmate 1430 no sat signal
replace the or recharge the battery to capacity and see if that helps usually low battery, incorrecty baud rate or port out cause no satellite connection, unless you are under a thick concrete or tin roof. take it outside and show it some sky and see if that help
Jul 23, 2009 | GPS
Triton 1500 GPS, I can't get any green bars to receive position.
You may have a few problems. First the GPS signal is controlled by a special GPS+ANT card in the 1500 and it may be defective. As for dates, etc. this could be caused by an other firmware update or a bad software file. Go to the Jungle Ghost Repair Center at www.jungleghost.com they have parts for the Triton units.
Dec 29, 2008 | Magellan Triton 1500 GPS Receiver
MAGELLAN 310 NOT TRACKING
Turn on the power while holding the right arrow. This resets the unit. You will then have to reset the time, date, and location.
Jan 22, 2008 | Magellan GPS 310 GPS Receiver
Does not reset location
I too have sometimes to wait for 20 mins before my Roadmate picks up all the satellites it needs. The problem is worse if I'm surrounded by buildings.
I have at last decided to bin the Magellan as it's been nothing but trouble and Magellan Support just don't seem to care to respond.
Am now getting a Tomtom Go series with all preloaded, maps/ traffic/ cameras - it auto updates each time it's put on its cradle attached to PC/internet.
Nov 07, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
147 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
