SOURCE: Power indicator light blinking
it looks like the battery is defective. try reseat the battery while the power cord plug in to see if that help. if you remove the battery and leave the power cord plug in, the battery symbol indicator light will turn off. Time to order a replacement battery.
SOURCE: dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
SOURCE: 1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
SOURCE: dell inspiron 6000 battery light is orange
remove the battery and insert again. if it continues then you will have to check the power source perhaps current it not enough for charging, if it continues then you will have to get a new battery
Testimonial: "Thanks for the help. That is what I expected."
