Question about Radio Communications
Need antenna for Brookstone ATR 1 radio - Radio Communications
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
Apr 06, 2016 | Brookstone Audio Players & Recorders
Brookstone Model cks 2022 Alarm clock radio Instructions
I searched on your product name and found an instruction manual for a Brrostone self-setting alarm clock radio:
http://www.brookstone.com/webassets/pdf/607960p_manual.pdf
Apr 23, 2014 | Brookstone SmartSet Alarm Clock
What does fuse called radio-b do?
If your unit has digital display as most do now, RADIO-B will supply constant power to power the units memory so it can remember the preset channels, starting volume etc. The power antenna is usually controlled by a separate wire from the unit (normally blue) this wire supplies a low voltage signal to the antenna, The antenna will also have its own power supply and earth at the base of the antenna, the problem could be there. depending on the antenna, some have a controlling relay that is separate, again another possible source. there will also be a fuse in the main fuse box. These will all need to be checked, along with connecting a power source to the antenna to ensure the antenna does actually work.
Feb 23, 2013 | Cars & Trucks
What kind of antenna does it use
All CB radios use a loaded antenna to match impedance of 52ohms from radio to the antenna.
Mobile and home antennas with a meter (swr) are adjustable for the lowest possible reading----1 to one or up to 2 to one readings indicate a useable antenna.
Readings are adjusted by adjusting the antenna for the lowest reading in the middle of the channels (19 or 20) and some radios have the meter for this built into the radio and some do not.
Running a radio at high swr (standing wave ratio) of over 2 to one reflects the transmit back at the radio and can damage the radio.
let me know if more specific questions
Mar 25, 2012 | Radio Communications
I have a Brookstone radio that has no model number but in addition to the radio has fastened on the side a projector for showing time and temperature on the ceiling. The projector has gradually lost...
Hi, would love to help you out,will be difficult with out model...so what you need to do is to, contact the manufacturer.
I would suggest you contact the manufacturer of your Brookstone radio via phone or e-mail and request for the service manual from them or help. They might give it to you or direct you to a dealer where you can get the service manual.
This is the best you can do to get the service manual you are requesting for.
Good luck.
Jun 10, 2011 | Brookstone Audio Players & Recorders
How do you set the time on Brookstone iDesign Cube Clock Radio?
Simply HOLD down the "CLOCK SET" button for ~3 secs and the time will flash... Rotate the dial around the SNOOZE button to the hour you want; click the "CLOCK SET" button again for the minutes and rotate the dial again... Hit the "CLOCK SET" button one last time and you're done!
Jul 05, 2010 | Brookstone (467522) Clock Radio
E020 sub code 0481
ATR Error (E020-XXXX) Display due to Dirt on ATR Sensor Window
Cause
The waste toner may adhere on the ATR sensor window or the sensor shutter. As a result of that, it may be faultily detected as ATR sensor fault and trigger the ATR sensor error (E020-XXXX).
The detail codes (xxxx) are as follow: XXA0, XXA2, XXA8, XXA9, XXC0, XX10, XX11, XXDA.
Filed Measure
Clean the ATR sensor window and the ATR sensor shutter with the following procedure. 1) Remove the ATR sensor from the main body. 2) Press the plunger [1] of the ATR sensor lever solenoid in the direction of the arrow. 3) Clean the ATR sensor window [2] and the ATR sensor shutter [3] with lint-free paper [4].
Pls rate thanks!!!!!!!!! dont forget testimonial mate.
Oct 17, 2009 | Canon CLC 1150 Color Copier
Tunning the antenna on radio shack cb trc-447
After installing the antenna, follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
The ideal standing wave ratio (SWR) is 1:1, or a meter
reading of 1 on the SWR meter's top scale. A SWR ratio
of 1.5:1 to 2:1 is excellent for most mobile CB antenna
applications.
Check the SWR on Channel 1 and Channel 40
If the SWR is higher on 1, make the antenna longer
If the SWR is higher on 40, make the antenna shorter
Most antenna's are adjustable. Make small adjustments at a time.
Oct 10, 2009 | Radio Shack TRC-447 CB Radio
Radio reception
the wire you use for the antenna is damage replace it or change the set to a other location.
Feb 19, 2007 | Brookstone Micro CD System with MP3 Shelf...
Radio Communications Logo
78 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
