Question about Hobart H600 Stand Mixer
Oil change thunderbird arm 60 - Hobart H600 Stand Mixer
I have a Hobart 60 qt mixer that has oil coming out the top around the shaft cover. What would cause this?
Do you really mean a 60 qt. mixer? That is industrial size and would be about 4' tall. Maybe a 6 qt. mixer? In either case, oil coming out around the shaft cover indicates that someone either over-lubricated the mixer or used the wrong viscosity lubrication. Has it been serviced recently? You might need to take it back to wherever it was serviced.
Feb 21, 2017 | Hobart Food Mixers
How do I change the gear oil in a food service mixer sp62
About 49 results (0.77 seconds) Search Results
    [PDF]Instruction Manual for Globe Mixers - Globe Equipment ...
    https://globeequipment.com/media/product.../Sp10_Owners_Manual.pdf
    Or call the Globe service department at 937-297-7247 and ask for contact .... Please remember that this manual or the warning labels do not replace the need to be alert, to properly train and .... gears or other parts and WILL void the warranty! 7. ... Lubricate the attachment shaft with a food quality grease or mineral oil. 4.
    SP62P 60 Quart Pizza Mixer - Globe
    www.globefoodequip.com/.../mixers/...mixers.../sp62p-60-quart-pizza-m...
    This mixer comes complete with an 60 quart stainless steel bowl, spiral dough hook and bowl ... High torque direct gear drive transmission; Oil bath transmission.
    Globe SP62P Gear Driven 60 qt. Commercial Planetary ...
    www.webstaurantstore.com > ... > Commercial Floor Mixers
    Commercial Planetary Floor Pizza Mixer - 3 HP. In stock ... What is White Glove service? ... Globe XXBOWL-62 60 Qt. Stainless Steel Mixing Bowl for SP62P Mixer.... Planetary grease fitting and gear oil meter. .... Globe SP62 and SP80PL MixerControls .... 2003-2016 WebstaurantStore Food Service Equipment and Supply .
Jan 30, 2016 | Globe Food Mixers
How do I trouble shoot a 7512 slicer to free up a frozen slide arm?
There's a Carriage Arm Knob that has to be loosened that could be a possibility also your supposed to lubricate it weekly with mineral oil.
Sep 26, 2015 | Univex Duro 7512 Slicer
Where do I drain the oil in a 60qt. thunderbird mixer
If you are referring to the transmission, I believe it's a sealed unit.
  • 3-Speed gear box
  • Transmission: Wide-faced, hardened alloy steel, helical gears fully sealed in transmission lubricant with heavy-duty ball bearings and clutch combine for highly dependable, quiet operation.
  • Jun 12, 2014 | Thunderbird ARM-01 Planetary Mixer
    My hobart n50 mixer,when pluged in does nothing at all. why? and what to do?
    The N50 is a heavy duty / commercial counter top mixer. It is available in several different versions for different power sources. Make sure yours is the model for use with the power available at your location. The power versions are:
    100-120/60/1, 100/50/1, 230/50/1, 220/60/1 and 230/60/1
    This lists the information in the following format: voltage/frequency/phase. If used in the US or Canada (and many other parts of the world) you would most likely want the 100-120/60/1 or the 230/60/1 version. All are single phase, so this shouldn't be an issue to worry about. Use of any of the other versions could result in shortened life expectancy of the mixer or immediate, catastrophic failure of the mixer and possibility of burns, shock or electrocution if connection is attempted.
    If the mixer matches the power available, check for proper wiring at the source point of connection and in the mixer. You may need an electrician to change the power at the connection point from 100-120/60/1 to 230/60/1 (or vice-versa since BOTH are available in North America). Also check to be sure that fuses or circuit breakers in the electrical panel are intact and on. Do not overlook GFI outlets if using the 100 to 120/60/1 version. Reset any tripped GFI outlet. If still unable to operate, verify that power is present at the connection point. If unable to operate, contact an electrician to check the power and wiring of the mixer.
    The mixer data sheet is available here.
    Jul 12, 2011 | Hobart N50 Stand Mixer
    What kind of oil use this
    I came across a manual for a Blakeslee f-40 60 80 and here is what it said. Hope this helps
    Lubrication
    The planetary and spiral-beveled gears are self-lubricated for life. The lubrication used is micromly grease and must be re-applied if gears are replaced. The transmission uses Mobil "delvic 1" synthetic oil which should last the normal life of the mixer. No lubrication is required for the auxiliary drive hub.
    If lubrication is applied to the auxiliary hub a grease-like substance will possibly leak out causing damage to the product.
    Applications of any lubrication will Void Warranty.
    berkelsalesservice.com/PDFs/DD-40_60_80.pdf
    Jun 27, 2011 | Blakeslee F-20-CA Stand Mixer
    What type of oil does a Hobart 60 quart mixer use?
    a H-600 takes part#102973-71, thehl600 takesthe same just less. dont for get to vote tks. monomoy
    Dec 11, 2009 | Hobart HL600 Legacy Stand Mixer
    Oil leak
    Possibly, but to be safe replace the seal
    Aug 21, 2009 | Hobart D300 Stand Mixer
    Hobart H600 Stand Mixer Logo
    53 people viewed this question
    Top Hobart Food Mixers Experts
    Ross Keen
    John Tripp
    John Tripp
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
