Question about Epson Stylus Sx535wd
Adjprog reset Sx535wd - Epson Stylus Sx535wd
Error 2100012C
This article deals with the various Communication Error issues when attempting to reset an Epson waste counter using an AdjProg service utility, which I'm pretty sure you're trying to do:
http://www.octoink.co.uk/kb/questions/119/
Dec 17, 2013 | Epson Office Equipment & Supplies
Epson stylus t30 error code 2100012c
This error is usually shown when using the AdjProg to try to reset the waste ink counter.
The error code is caused by one of the following:
1. More than one Epson printer is connected (turn any others off)
2. The utility can't connect using the "Auto" setting for the printer "port" (Select the specific printer port using the "Select" button).
This issue is covered with other AdjProg errors in this article
Jan 09, 2013 | Epson Stylus C84 InkJet Printer
EPSON STYLUS SX535WD WONT PRINT FROM MY COMPUTER
Probably not what you want to hear but the fastest way might just be to unplug the USB, uninstall the software, and re-install it. That should fix the problem.
Oct 10, 2012 | Epson Stylus Sx535wd
We cannot turn the epson printer. It doesn't react.
Before I do anything I would first check with Epson. Here is link to a support faq on this issue. If that does not clear up your issue then its more than likely the case that you have a bad power supply or bad engine board. Both parts with labor will cost you more than you paid for the machine.
Sep 12, 2012 | Epson Stylus Sx535wd
Message tells me my Epson 250 needs service - ink pads full. Can I fix this myself as will cost more than the printer is worth if I take it to a service store?
Steps :
Before the prototypal run AdjProg take the steps below
- Machine On
- Contain the enter properties of restricted AdjProg
- Run the line Companion pyrotechnic introductory Stamp according to the modified Stamp AdjProg.
- Change the engagement to flowing day qualified AdjProg ( july, 11 2007 )
- Run the registration promulgation
- Superior Get
- Select a specific advance average
- Select "Ravage ink pad sideboard - OK
- Click the "initialization"
- Movement off the machine and on again
Mar 21, 2011 | Epson Office Equipment & Supplies
What will i type or what date shall i type when resetting my epson r290printer?helppppppp
If you ask about the waste ink counter reset follow this instruction.Otherwise ignore this.
Epson R280, R285, R290
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
Oct 27, 2009 | Epson Stylus R290 InkJet Printer
Same problem have espon r285 cant find service utility for reset
First of all download this.Extract to your C drive. Run indoreset.bat, then follow the instructions. After that right click AdjProg and select properties. Go to compatibility and select Windows XP. Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this option). When working accept the agreement and go to
3. Click Check
4. Tick both boxes.
6. Then it's done.
Oct 14, 2009 | Epson Stylus Photo R220 InkJet Printer
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Jun 01, 2008 | Epson AcuLaser C900 Printer
EPSON 360
download a ink pad reset utility at epson.com/ipr or there are some other 3rd party s/w for ink pad reset
Feb 19, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Sx535wd Logo
163 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
