Question about Humidifiers
Aprilaire fan won't kick on - Humidifiers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 179 Answers
Is the air unit plugged in electrically?
Posted on Oct 18, 2013
I have an aprilaire model 6303 control panel, and the B and G terminal lights are on, on the equipment output and the fan runs continously. Is the board bad or what please help
[PDF]Aprilaire® Zoned Comfort Control® Product Guide
ftp://ftp.aprilaire.com/...Control/5050_ZCC_productguide.pdf
AprilaireAprilaire Model 6303 Control Panel ... with the Model 6504 Intelligent Zoned Comfort system, we have the right control for your ... A control panel coordinates the operation of the equipment with the ..... Proper control of the fan (G-terminal) for either electric.... Auxiliary output relays available to control humidifiers, electronic.
[PDF]Safety & Installation Instructions - Aprilaire
ftp://ftp.aprilaire.com/Fulfillment/Inbox.../6404_install_guide.p...
AprilaireModel 6404. Zoned Comfort ... Do not mount the control panel on any part of the heating/cooling equipment or ... allowing for control of a humidifier. b. HUM LEDlights when the relay is closed. .... on the fan (G output terminal) with a heat call (W1output ..... Run wire between the HVAC equipment and the control panel. 3.Missing: 6303
Jan 20, 2016 | Aprilaire Humidifiers
After a few hours my Aprilaire 400 makes a constant clicking sound that won't stop. Is it the solenoid?
This is either the solenoid or a loose low voltage wire. Make sure all the wiring connections are tight, if they are the solenoid if bad and will need to be replaced.
Dec 14, 2012 | Aprilaire 400 Humidifier
Aprilaire model 50 current sensing relay won't close
If the relay is not closing then it must be replaced. It works by sensing the current through the common wire of the blower motor.
Dec 08, 2012 | Aprilaire 50 Current Sensing Relay...
When furnance turns on and the blower kicks in the fan from the humidifier does not turn on ?
The first to check is if you are getting 24 volts to the solenoid valve and if you are getting 120 volts to the humidifier via receptacle.
Dec 29, 2010 | Aprilaire 700 Humidifier
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Aprilaire 600 humidity level too low
The max the aprilaire can put out is 45% Rh. Your humidifier may wired up to run only when the heat is on. In some cases this is not enough time to maintain your humidity level your seeking. To correct this, the hum. has to hooked up the hot side of the water supply. And the humidifier has to be hooked up when the fan runs and leave the fan run constantly
Jan 12, 2009 | Aprilaire 600 Humidifier
Humidifier won't turn on with furnace fan set to Auto.
There is a devise called a current sensing relay (a little black box that hangs on a blower motor wire that senses current from that wire) If you have such a devise it should hang from the white (common) wire. Loop the wire through twice.
Nov 23, 2008 | Aprilaire 600 Humidifier
Humidifiers Logo
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
