Bios settings boot
MY 2004 DELL REV. A01-00 GOT IT'S SETTINGS ADJUSTED BY MYSELF READING OUT OF AN OLD BOOK,IN ORDER TO ADD AN EIDE HARD DRIVE. NOW I GET A BLUE SCREEN WITH BLURRY LINES OF WHAT I BELIEVE ARE THE SET UP OPTIONS. BUT I CAN'T DO ANYTHING. PLEASE WHAT SHOULD I DO?
    Brigadier General:
  • 3,400 Answers
IF POSSIBLE SET OPTIMAL DEFAULTS,OR CLEAR CMOS.
Posted on Oct 18, 2013
4 Suggested Answers
florin_decad
  • 203 Answers
SOURCE: Changed bios setting will not let me enter setting again or boot
try boot from floppy disk if there is one floppy
Posted on Jan 27, 2009
  • 300 Answers
SOURCE: Advanced BIOS setting
I would suggest using the set bios default option on the main screen. This should reset everything to factory defaults.
Be sure to exit saving settings. After that, assuming there's no hardware damage, it should start fine.
Hope this helps. Please remember to rate this information.
Thanks
Posted on May 13, 2009
SOURCE: Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Posted on Dec 26, 2012
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Oct 03, 2011 | Dell Computers & Internet
Replaced hard drive and now it won't boot up, says hard disk not found
Did you set the jumper(s) on the new drive to match the settings on the old drive (usually CS or Cable Select)?
Did you double check the power connector was snug on the new drive? You may also want to double check the connector on the motherboard, SF systems are cranky about moving around, and mave have unseated the motherboard end of the cable.
Sep 08, 2010 | Dell OptiPlex GX150 SF PC Desktop
A1430N Moved my two working ide drive 250G over
Hello
Thank you for using
FixYa for your problem
IDE will try to boot first when pluged in, sata will not boot. I think there is a adjustment in the BIOS setting to have the SATA boot first
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | HP Pavilion a1430n (ER900AA) PC Desktop
Bio Won't automatic Boot
so to bios setup and go to boot, and change the boot order of your drives, dvd/cd rom, and hard drive changer the boot order to hard drive and escape enter and save exit and reboot
that should resolve the problem
Jun 21, 2009 | Dell Inspiron 1100 Notebook
Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Mar 15, 2009 | Dell Dimension E521 PC Desktop
1TB Western Digital External keeping system from booting up
You need to go into the BIOS of your computer and change the boot order of your computer.  Your computer must be set to boot from your main hard drive only.
Mar 05, 2009 | Western Digital My Book Essential 1TB...
Additional hard drive instalation.
Did you check the boot sequence?
Just make sure that the HDD wich is set to boot from is the same wich is containing the OS.
Nov 26, 2008 | HP Pavilion a1610n PC Desktop
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
1st and 2d eide conector on mobo
Hi, Does not really matter whether slave via jumper or cable select on the secondary IDE. Your mb will boot to whatever HD you set it at in the BIOS/CMOS as the first boot device. The 3rd drive will be recognized as secondary whatever and if your CMOS/BIOS is set right it will boot from the primary master on IDE1. Good luck and kind regards.
Oct 09, 2007 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
