I dont know how to put timer in my switch master
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
What is a switch master
Posted on Oct 20, 2013
How to wire a four function switch
4-function switch can be 4 individual switches in a bank of switches, or it can be a combination of switch and timers.
Some timers need a neutral wire, while others, such as spring-wound timers do not need neutral wire: each of these items is wired separately.
Copy following link for switch illustrations, including 4 function switches.
http://waterheatertimer.org/How-to-wire-switches#gang
http://waterheatertimer.org/How-to-wire-timers.html
Jul 27, 2012 | Broan-NuTone FAN CONTROL SWITCH
I have a intrermatic r8816p101c that some one removed need to put new one back dont know how i have 2 red wires coming from pump and to red wires coming of the wall witch has a on and off switch how do i...
You have Intermatic 240Volt sprinkler timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8816p101c%20-%20english.ashx
Timer relay has 4 wiring terminals: from left to right 1 2 3 4
Red wires from switch connect to terminals 1 and 3
Red wires to pump connect to terminals 2 and 4
Since circuit is 240Volt, red wires from switch can be connected in either order. Same with pump.
Rain sensor terminals don't have any wires, unless you but separate rain sensor.
Parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Aug 10, 2011 | Intermatic Hardware & Accessories
Timer light blinking but ac doesnt start. how to cancel timer
Since you didn't mention what make or model AC unit you have, I can only tell you what to do in generalities. Turn the Master ON/OFF to OFF and unplug the unit for 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during the 15 minute timeout, the unit's electronics reset them self and reverted back to the original factory settings. If so, you can set the controls however you desire.
Hope this helped you. Please let me know.
Jun 30, 2011 | Heating & Cooling
Passenger front and drivers rear wont go down master swicth works but those window dont on master or on door.
IF MASTER SWITCH DONT WORK PASSENGER FRONT AND DRIVERS REAR.BOTH SWITCHES OKAY TO EACH WINDOW.THEN THE MASTER SWITCH IS FAULTY.
Feb 17, 2011 | GMC Yukon Cars & Trucks
Hi i got a 95 acrua legend 4 door my power windows dont work but the drivers works fine the window motors work finein the other three windows by hot wireing one side and gounding the other side the...
Ground goes through the master switch on the drivers side. Bad master switch can cause the other windows not to work. Don't forget to check the "window lock" switch in the master switch, which shuts off the other 3 windows.
Jan 16, 2010 | 1995 Acura Integra Coupe
Dont spend
Since the spinning is depended on the timer most common of all problems is in the timer switch which sends signals to switching valve to open fill or drain and close the timer is basically a clock. It should only be turned clockwise.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Washing Machines
Electric Windows
yes, dat can b ur problem. check under the master switch to c if wire is nt loose. u need a test lite to check if power comin to it b4 changing it. easy put ur test lite **** on any metal that dont hav paint. put da sharp point to the wire undre da master switch and press botton, check wires 1by 1 wen u press it da lamp should lite up. oh yeah key must b on on position wile testing
May 12, 2009 | 1996 Ford Explorer
Rear side windows
This may be just a case of inadvertently hitting the window lock out n th driver door window switch by mistake. Check that first. Here's some background on window operation
Principles of Operation
The driver power window regulator motor is controlled directly by the master window/door lock/unlock switch (and its integrated "auto down" module). Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The driver power window regulator motor is a reversible motor that is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The passenger power window regulator motor is controlled directly by the passenger power window switch and can also be controlled by the master window/door lock/unlock switch. Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The passenger power window regulator motor is a reversible motor, which is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The power rear quarter glass is also directly controlled by the master window/door lock/unlock switch. The power rear quarter glass power latches also utilize reversible motors. The power rear quarter glass power latches are operated by applying power and ground to the motor leads to open the window, and then reversing polarity on those same leads to close the window.
Symptom Chart Condition Possible Sources Action
  • All windows are inoperative
  • BJB Fuse:
    • F20.
  • Circuit.
  • Power window relay.
  • Front door power window switch.
  • GO to Pinpoint Test A .
  • Single power window is inoperative
  • Front door power window regulator.
  • Circuit.
  • Driver door power window switch.
  • GO to Pinpoint Test B .
  • Vent power window is inoperative — quarter window glass power latch
  • Circuit.
  • Quarter window glass switch.
  • Quarter window glass power latch.
  • GO to Pinpoint Test C .
  • The one touch down feature is inoperative
  • Master window regulator and door lock switch.
  • INSTALL a new master window/door lock/unlock switch. REFER to Switch—Master Window Door Lock/Unlock .
  • The back window will not defrost
  • CJB Fuses:
    • F30 (10A).
    • F32 (20A).
    • F34 (20A).
  • BJB Fuse:
    • F27 (45A)
  • Circuit.
  • Heated back window switch.
  • SEC/timer module.
  • Rear window defrost relay.
  • GO to Pinpoint Test D .
  • The back window defrost will not shut off automatically
  • SEC/timer module.
  • Circuit.
  • GO to Pinpoint Test E .
Jan 28, 2009 | 1999 Mercury Villager
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
