Question about Husqvarna YTH23V48 23HP Lawn Tractor 960 43 0086
Pull pto buttom and motor dies on husqvana yth23v48
2 Suggested Answers
  • 130 Answers
SOURCE: Husqvarna tth2148
sound like you have a safty switch bad
Posted on Jul 18, 2009
2009 bad boy stalls when engage pto
Check pto and seat safety switches.
Sep 04, 2017 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
I have check pto switch /my clutch is ok/but when i pull pto switch engine strees out
check all of the bearing in the mower deck .you might have one or more stuck .
Jul 09, 2015 | Husqvarna Garden
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
I place all my safety switches on my husqvarna zero turn so what else can cause the motor too die when i take the hand brake off or engage the pto(replaced pto switch)
a bad bad bare wire will cause that chase the wiring looking broken or bare wires try to hold engine rpm im up manually with hand on throttle dont let the govenor pull it down if it runs you have linkage problems take to shop let them adjust and look for bad linkage
Sep 12, 2014 | Husqvarna Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
PTO and safty switches dont work
If this mower is a husqvana then one of the four relay is bad
Jun 17, 2013 | Garden
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Apr 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna tth2148
Jul 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH23V48 23HP Lawn Tractor 960 43 0086 Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
