Question about GE VintaDeluxe Toast-r-oven Toaster General Electric A12 T93b A12t93b
Manual pdfmodels ceramic insulator broken
DOES GE TOASTER OVEN MODEL 169051 HAVE AN UNDER CABINET MOUNTING BRACKET? THANK YOU !!!
If yours is the one with the rounded top it does not have an under cabinet mounting bracket. The top of the oven is not insulated so it would heat the cabinet above and cause a fire
Dec 28, 2017 | Toaster Ovens
Heating element on toaster oven have mercury in them
No they don't. If they did it would be online and they would never get through inspection anyway. Mercury is expensive, but you do find mercury in all florescent tubes and compact florescent lamps in very small quantities. Toaster oven elements are radiant and have a metal element inside a ceramic glass tube.
https://www.google.ca/search?q=Heating+element+on+toaster+oven+have+mercury+in+them&sourceid=ie7&rls=com.microsoft:en-CA:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=bokqWOz-NoWN8Qe66IegDw
Heating element on toaster oven have mercury in them Google Search
Nov 15, 2016 | Toaster Ovens
OVEN NOT BROKEN JUST WANT A MANUAL TO MAKE THIS OVEN WORK CORRECTLY
Elizabeth, Google search your Microwave make and model# manual. This is how I would do it.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 01, 2016 | Toaster Ovens
Light turns on, but no heating.
Pull apart again. you will see leads insulated with cloth-like insulation. feel for a bulge or two - usually a fuse is hidden in one of those insulations. Find it test it for continuity. If flown, cut it out, replace or just short out that connection.
Jul 21, 2009 | Krups 296 ProChef Ultra 1500 Watts Toaster...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
My KA KCO100508B blew its thermal fuse after 3 years. I found a replacemnt close to 206 centigrade for $2.60 at Appliance Parts Warehouse near my home in Smyrna, GA. Know what to ask for when you enter APW. They don't like selling potential fire hazards to novice repairpersons!
Mar 05, 2009 | Toaster Ovens
Instruction book for Euro Pro X toaster oven
Euro-pro.com, select toaster, plug in your model and choose manual. Just printed mine.
Mar 01, 2009 | Euro-Pro EuroPro 6Slice Toaster Oven with...
How do I obtain a user manual ?
Hit the download MANUAL pdf button on this page:
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=TO160
Covers both 160 and 160L models.
Apr 09, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
GE VintaDeluxe Toast-r-oven Toaster General Electric A12 T93b A12t93b Logo
Top GE Toaster Ovens Experts
Mack Baxter
Tom Chichester
Bill Boyd
Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
