Question about Canon 35-70mm f/3.5-4.5 FD Lens
Camera lens focus problem
Photos from my lens are fine in about 70% of the area, but in the bottom left corner and up to maybe 1/3 of the height and 1/3 of the way in towards the right the image is soft.
  • 2 more comments
  • the_nool Nov 03, 2007
    Thanks Joel.
    I had found that out in the time since I posted.
    The lens in question is a canon 28-70 2.8L (and my favorite) which has served me excellently before this.
  • gtvetner Jan 04, 2009
    I can not get the lense to focus, the photo's are comming out all out of focus
    thank you
    tanya
  • carlonoswad Jan 10, 2009
    I have just purchased the Opteka 1300L HD lens and cannot focus to get a crisp picture. Near distance was better but not as good as it should be. Am I doing something wrong?
  • solderfix May 11, 2010
    It sounds like you might have moisture in the lens, or possibly some fungus growing on it.  If you take the lens off the camera and look through it, do you see any fogginess?  If you are lucky it is something on the outside of the lens that can be cleaned off.
    The 28-70L lenses should be pretty well sealed from moisture.  It could be that a seal has leaked.
  • 37 Answers
What lens is this? Sometimes a particular copy of a lens can have misaligned elements (some lenses are more well-known for this than others). If it is new you can return it and ask for an exchange. If its not new it'll need adjusting by the maker or a shop.
Posted on Nov 03, 2007
Autofocus problem with 70-300mm is usm
Replace the broken ribbon cable in the lens
Sep 23, 2012 | Canon EF 70-300mm f/4-5.6 IS USM Lens
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
PHOTOS ARE BLURRY
Are you taking them in a dark area? If so you must hold your hand extra steady for these kind of shots. Also check your exposure settings, they maybe off.
Apr 12, 2010 | Canon PowerShot SD600 Digital Camera
Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
Sep 28, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Nov 23, 2008 | Canon EOS Rebel G 35mm SLR Camera
Canon 70-200mm f/2.8 IS lens not focusing
I have had to replace the focusing servo motor is these before. The problem of seeking without locking in may mean the same for your lens. Do check for a dirty filter on the front and look to see if the rear optic is dirty or cloudy first. I'm assuming other lenses work fine on your camera.
Jan 05, 2008 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Camera won't autofocus
Auto-focus technology on this camera is controlled by several contacts on the mount that physically mate with other contacts on your lens. It sounds like your mount may be malfunctioning due to wear and tear (if cleaning does not work). This is between $100 and $300 fix depending on which part(s) need replacement.
Oct 24, 2007 | Nikon D50 Digital Camera
Sony DSC-W100
I think ya camea has developed a hardware fault.. maybe time for the camera Shop fixit man ... I found a manual maybe that'll B some help? http://www.sony.co.uk/view/ShowProduct.action?product=DSC-W100&site=odw_en_GB&pageType=manual&imageType=Main&category=DCC+Digital+Still+Cameras
Jan 27, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Canon 35-70mm f/3.5-4.5 FD Lens Logo
393 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
