Question about Dell Computers & Internet
PCIe training error: slot 2 - Dell Computers & Internet
2 Suggested Answers
  • 2427 Answers
SOURCE: If we use the server
The problem seems to be 2 things..
1.) firstly send the boot priority in the bios to HDD 0 or the harddrive connected directly to the board with the os.
2.) second thing, the Raiser Card, if it has raid Harddrrives connected via the ext. one of the raid harddrives connected to it is malfunctioning , remove and disable one at a time until u find the correct one. Or it could be the Card itself is malfunctioning.
I'm guessing here that you have a IDE card connected to the Raiser card with raid harddrives on it, One of them is malfunctioning.
Posted on Apr 01, 2011
ASUS m5a97fx pci express x16 slot stopped working no fans and no video slot #2 has fans but no video switched cards and power cables still nothing
That would indicate a problem with the MOBO since the 'Blue' PCIe x16 slot is ideally meant for the GPU. Things to try:
1. Clear CMOS (unplug the PSU for 5+ minutes) use the CMOS Jumper 5+ seconds ; see - http://www.youtube.com/watch?v=rdHH9KrceR0
2. Boot into the BIOS and press (F5) to Load Defaults, save and shutdown.
3. Blow-out and ensure the Blue PCIe slot is clean and the GT 430 is properly seated, and to my knowledge there's no additional power (PCIe power pins) - but if there is then connect per the GPU's manual.
http://www.tomshardware.com/forum/315008-30-pcie-slot-problem
Jan 14, 2017 | ASUS Computers & Internet
How to fix pci express error for Toshiba Qosmio G40?
Whatever is plugged into your PCI Express slot is defective and needs to be replaced, or re-seated (unplugged and plugged back in). Also if something went defective on the PCIE slot it may have also damaged the circuitry on the motherboard around the slot.
The Wireless network adapter may be connected via a PCIE slot. You may also have a little plastic trap door underneath your laptop where you can have access to the card. There are 2 pigtail connectors with wires that u can just pull off the terminals and then It has 2 clips on the sides of the card keeping it flat. You open the clips and it pops up in a more vertical position, then you can slide it out and reboot to see if the error is still there or not :) If its gone try plugging it back in and seeing if the problem's resolved by re-seating the card. If it works without the card installed you should buy another wireless network adapter.
Hope that helps
Christopher
May 15, 2012 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
If we use the server without PCI-PCIe Raiser card, it can boot into the OS. However, it cannot boot into the OS when we install the PCI-PCIE Raiser Card into the sever, and it alerts message error as...
Apr 01, 2011 | Dell PCI-X Riser Card for PowerEdge R200/...
How many PCI slots available with DELL desktop
Mostly of all kinds of motherboard have 3 PCI slot an 1 PCIe slot. But there are some have more than that.
Aug 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How can i tell the difference between pci slots and pcie slots
The Peripheral Component Interconnect or more commonly known as PCI is a standard for connecting a lot of devices inside your computer to extend its capabilities. Devices like sound cards, modems, NIC, TV Tuners, and some video cards have at some point or another have used the PCI port.
PCI express ( PCI-E ) is a much improved version in terms of speed. PCIe uses a serial interface instead of the old parallel interface used by PCI. It also utilizes individual buses for each of the devices connected to it instead of a shared one like what PCI uses. The difference in speed is quite huge when comparing the standard PCI slot which runs at 133MB/s to a 16 slot PCIe that can send or receive up to 16GB/s.
The most common use for PCIe nowadays is with graphics cards which benefits hugely from the huge bandwidth provided by the interface.
1. PCIe is much faster compared to PCI.
2. PCIe uses a serial interface while PCI uses a parallel interface.
3. PCIe speed is classified into lanes, each capable of delivering up to 1GB/s data transfer.
4. PCI slots are standardized while PCIe slots vary depending on the number of lanes the slot is intended for.
5. Despite PCIe superiority, most manufacturers still use the PCI standard for their devices.
Unlike PCI slots which are the same size for all devices, PCIe slots can differ depending on which form factor it accepts. The longest would be the 16 lane slot and understandably, the shortest is for the x1 devices.
I hope this much information is enough for you to understand the difference between both of them. If you need any more help let me know.. !
May 13, 2010 | Dell Dimension 3000 PC Desktop
Dell Optiplex GX620 not recognizing PCIe video cards
One of two things could be doing this:
1: Bad Video Cards
2: Bad PCIe slot(s)
If avaliable, I would test the video cards on a PC with a PCIe slot to verirfy if the cards are good/bad. If they work, your PCIe slot is bad and need to have the motherboard replace to correct.
Good Luck
C2Solutions
Aug 27, 2009 | Dell OptiPlex GX260 PC Desktop
I am using AMD 6400+ with M2N VM DVI WITH VGA card GT8600 1 GB but my graphic doesn't support what is the problem please tell me.
Your problem may be your in the wrong slot. My m2n board has 2 pcie slots. One is an X8 and the other is X16. Your card may be in the wrong slot. The blue one is the X16 and the black is X8. If you are using 2 PCIe cards the X 16 slot will only run at X8. Hope this helps.
Jul 09, 2009 | ASUS Computers & Internet
I need help choosing a video card - part 2
PCI is the older, slower format, PCIe is newer and faster, but your system MUST support PCIe or it won't work.
So easy option is to find if your system supports PCIe and then get whichever is suitable.
May 13, 2009 | Intel D101GGC Motherboard
Computers & Internet Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
