Question about Nature's Miracle Self-Cleaning Litter Box
Nature's miracle self cleaning litter box stuck
I have the self cleaning litter box. It's making a loud clicking noise and not rotating properly. I have taken it apart, cleaned, & reassembled it but it's still doing the same thing
First of all make sure you have assembled it correctly and there is no obstructions, if you have the instructions. You can probably contact the company that might send pieces to help repair the litter box.
Jan 09, 2017 | Cats
When rake cleans makes loud noise
Open the left side of the box and you'll see a white plastic part covering the hole. Get scissors and cut it out. The metal piece moving the rake was dragging on the plastic and so I cut it out of mine and now it's back to normal !
Jan 02, 2016 | LitterMaid Mega Self-Clean Cat Litter Pan
HOW DO I DOWN LOAD THE MANULA FOR THE LITTER MAID SELF CLEANING LITTER BOX? I NEED A NEW SWITCH FOR IT BUT DON'T KNOW HOW TO TAKE IT OUT.
http://www.useandcaremanuals.com/pdf/lm500-lm950138.pdf
Not sure what windows or operating system you have but when you pull up the link in the lower right you will see print download / save when you put your mouse over the lower right corner
Dec 08, 2014 | Cats
What litter box cover works for breeze
I MADE MY OWN OUT OF A CARDBOARD BOX FOR MY LITTER MAID SELF CLEANING LITTER BOX AND IT WORKS GREAT. KAT AT ACOLLINS3@AOL.COM
Aug 14, 2014 | Tidy Cats Breeze Litter Box System for...
Littermaid LM980 Turns itself off
The other appliance, e.g., a motor driven one, may be causing the box to malfunction. You may have to use a dedicated connection to get proper results.
Mar 06, 2014 | LitterMaid LM980 Mega Self-Cleaning Litter...
XNon functioning littermaid LM980 mega
Common problem with Littermaid boxes. Try a better brand of clumping litter. Try using a little less litter. And you can help the rake lift up by slowly pushing on it with something, giving it more strength. I had this problem and found that if I "helped" the rake return to its normal position, it would work most of the time, and then need "help" every once in awhile. I actually gave up on littermaid type boxes...they just don't work very well.
Oct 29, 2012 | LitterMaid Lm980 Mega Self-cleaning Litter...
If I buy a self-cleaning litter box does that mean that I am off the hook for cleaning?
Sorry to break the news to you but just because you bought a self-cleaning litter box does not mean that you do not need to clean it. While they keep themselves cleaner than other litter boxes, self-cleaning litter boxes still require an amount of sanitary maintenance. They necessitate regular washing and litter replacement. You should also keep an eye out for any waste that the self-cleaning system may have missed.
Aug 14, 2012 | Cats
I would really like my cat to have a clean litter box throughout the day. Do self-cleaning litter boxes really work? If so, this could be a worthwhile investment.
I would recommend you check out the LitterMaid litter box. It has two sensors on either side of the box that detect when a cat uses it. After 10 minutes, a rake automatically comes and scoops clumps of solid and liquid waste into a disposable container at the end of the litter box. Keep in mind that this does not eliminate you cleaning the box.
Aug 14, 2012 | Cats
Where can I buy a self-cleaning litter box for my cat?
Self-cleaning litter boxes are increasing in popularity and are available at most local pet supply stores in your area or online. Here are a few places for you to search and compare.
http://www.littermaid.com/
http://www.petco.com/product/100832/ScoopFree-Automatic-Self-Cleaning-Litter-Box.aspx
http://www.litter-robot.com/
Aug 14, 2012 | Cats
How much are self-cleaning litter boxes?
Self-cleaning litter boxes can range from $45.00 - $350.00.
Aug 14, 2012 | Cats
Nature's Miracle Self-Cleaning Litter Box Logo
243 people viewed this question
Top Nature's Miracle Cats Experts
RANDY POWERS
Level 1 Expert
Tom Chichester
Ruth summersides
Are you a Nature's Miracle Cat Expert? Answer questions, earn points and help others
