Question about Smartpool Nitro Robotic Cleaner and Caddy
Cleaner would start cleaning for about 30 sec then stop and stand straight up on its back roller
    Top Expert:
  • Smartpool Master
  • 8,163 Answers
Bad motor
Posted on Dec 09, 2017
Bad running lp2844
sounds like bad or dirty input rollers. there is a citrus based cleaner/rubber rejuvinator that will restore their pickup ability, but ultimately if cleaning doesnt work, the part will need to be replaced.
Jun 02, 2014 | Zebra LP2844- DIRECT THERMAL PRINTER-...
Electric wont stay started
Carb not getting enough fuel. Sounds like a malfunctioning fuel float or needle valve issue. Clean first with carb cleaner and/or rebuild the carb.
Nov 08, 2013 | Electric Lawn Mower
Vaccum afuera 550 start few minutes and stop few secondes, after 10 min its stop 30 sec and start 3 sec, after 20 min start ok
Your vacuum may be clogged, overheating and shutting off. Check for obstructions in the hose by laying it as straight as possible and shining a flashlight in one end while looking thru the other end. If you have a curved hose end, try holding the suction hose from another vacuum while checking for airflow in the opposite end.
Nov 06, 2013 | Electrolux Central Vacuum
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Oct 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My tiger shark pool cleaner will run for about 30 sec. then shut off. how can i fix this problem?
The pool cleaners impeller may be clogged or jammed with debris. Check and clean if necessary. The brush rollers or drive tracks could also be stuck. Check for debris and remove. It is most likely one of these problems if it is shutting off after only seconds of running. If these don't seem to be the problem, I would check your power source.
Aug 18, 2010 | Aqua Vac Tiger Shark
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
DVD WILL ONLY PLAY 30 SEC, THEN STOPS
Usually an inspection of the play surface will reveal fingermark or dirt and scratchess when thi soccurs try cleaning both the optical eye with a dvd disk cleaner and clean the dvd with cleaner and cloth ( not in circular motion) but across the DVD.
Jun 23, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Brush roller not working on Bissell proheat 7920
my brother changed the roller belt, but now the rollers won't stay up so I can move the cleaner and the water isn't getting sucked up.
Apr 17, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Smartpool Nitro Robotic Cleaner and Caddy Logo
75 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
