Technics su x320
Both speakers only work with surround on
megatronix
  • 57 Answers
SOURCE: Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
perkoo
  • 17 Answers
SOURCE: Technics Integrated amplifier su-v85a speaker
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: starilaz@net.hr
Posted on Dec 21, 2009
Grubhead
  • 5487 Answers
SOURCE: Hello! I have a problem with Technics SU-V2X
Well whatever is playing up sounds like it might be getting too hot to me. In any case it's something common to both channels. Just have a look on the heatsink to see if it uses a single IC for both channels, they are can cause lots of problems!
The IC might be marked STK with numbers after the letters. That is the part number too for ordering a new one.
Posted on Jan 12, 2010
  • 4234 Answers
SOURCE: Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Posted on Mar 15, 2010
Benimur
  • 6966 Answers
SOURCE: what speakers can i used for technics su-v55a
Hi and welcome to the site,
The specifications prescribes:
  • 4 ~ 16 ohms if either MAIN or REMOTE is used;
  • 8 ~ 16 ohms if both MAIN and REMOTE are used at the same time.
Offhand, any 8 ohms speaker rated at 60 ~ 100 watts would be compatible.
Good luck and thank you for asking.
Posted on Aug 18, 2010
Still not working
assuming you mean the technics su-ch7 amplifier from your previous post
I have searched fixya and this forum below has been referred before on fixya previously for advice on your amplifier
http://www.allaboutcircuits.com/search?q=technic+su-ch7
and the original posting
http://www.fixya.com/support/t7155686-just_bought_tecnics_su_ch7_integrated
Mar 23, 2016 | Audio Players & Recorders
How do i hook my speakers to my amp
Your amp has separate outputs for rear channels. Simply connect your rear speakers to the outlets on the back of your amp set up for them.
Jun 11, 2015 | Technics SU-G75 Amplifier
Technics su-x950
Many surround amps have test tones to that go to each speaker to test if the wiring is good. If your model doesn't have them, use a THX rated DVD. This will have on a menu a THX test tones for speakers. If the connections are good, then some amps have the ability to switch off speakers. Check your manual to see if this is the case. If you have Surround signals going in to your receiver everything is set up right, then the only other cause is a power amp failure for the effected channels.
Mar 12, 2014 | Audio Players & Recorders
Good day i have a Technics amplifier SU-X320. Problem is it powers up up there is no sound. Checked all basic fault finding, suspect it is the volume IC.
"Volume IC" do you mean an IC that is a pre-amp and controls the volume and things like tone? Or do you mean the main power amp IC, which will be on the big heat sink?
If you amp uses the latter and not individual separate devices for the power amp, suspect that over the other IC. But if the amp has separate power amps for both channels, replace the IC.
Oct 09, 2013 | Technics Audio Players & Recorders
Speakers for Technics SU X933?
check given link for speakers
http://www.fixya.com/myhome.aspx#Answers
Jun 05, 2012 | Technics SU-G75 Amplifier
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Jan 21, 2008 | Audio Players & Recorders
63 people viewed this question
 Grubhead
Grubhead
