Question about Thermos Grill2Go Gas Grill 4656110
Need regulator - Thermos Grill2Go Gas Grill 4656110
Replace driver side window regulator & motor
You will need to remove the door panel. To do this look for screws on bottom and the armrest also some by the door handle. after you get the screws out start at bottom and carefully pry out the door panel. There are clips that pop out. once you have disengaged the clips you will need to slide the door panel up to remove it. Then locate the bolts that hold the regulator and motor and remove them. The motor should come out with the regulator together. \you will need to unplug the elect. connectors. Be careful not to drop glass into door as it could break. \you will see how the glass attaches to the regulator. ( reverse to install new regulator)
Mar 01, 2014 | Vehicle Parts & Accessories
What regulator does a empire model 115 15000 btu take?
The regulator on the heater probably is not but is probably a device to prevent the heater being used unless the gas pressure is high enough and also serves to prevent air entering the gas line and also serves to arrest flashbacks.
The standard propane low pressure regulator is 14" water gauge but the heater might need a high pressure regulator. The best way to decide which type of high pressure regulator to use, because there are several, is to use an adjustable regulator.
After installing the adjustable regulator the pressure is increased until gas can be heard to be flowing and the heater lit. The regulator should then be adjusted to produce a clean flame of the correct length and then the regulator adjustment locknut should be tightened.
If the heater is to be used indoors it is important to ensure there is plenty of ventilation and the emissions are checked by a gas engineer.
Sep 06, 2017 | Empire Heating & Cooling
Blew off regulator knob
Parts can be ordered form www.toolpartsdirect.com. Air regulator should be adjusted with very little air pressure in the system. If you are adjusting the regulator with full tank pressure, you are overworking the plastic parts within. Over time, water will rust parts inside of the regulator. I would order the complete regulator. You could also remove the regulator part of the manafold and use full pressure to the quick connects. If you need to regulate the air pressure down a bit, purchase a universal regulator and install quick connect fittings. Male fitting to air in and female fitting to discharge port. Install this regulator to one of the quick connect fitting on the a/c. Good luck
Dec 23, 2013 | Hitachi EC119SA Twin-Stack Air Compressor...
I need a diagram to show how to hook up pressure regulator
This is my advice if you dont already have a regulator. Go to menards or lowes andlook for a regulator kit. They usually come with everything you will need to put a good one on your compressor. Instructions will come with it along with the threaded pipe to hook it up with. I myself just got a pressure regulator kit from Theisenes.
I started by removing my air hose from the tank, next youll need to attach the regulator to the tank where you removed the hose, your kit should have prethreaded
metal air pipe to go from the tank to the regulator (use thread tape or joint sealer to prevent leaks ) Now use your sealer to seal airhose to the other end of the regulator the airoutlet side. Turn it on abd check for leaks and see if you can set your pressure regulator to a set pressure If it holds without leaking you did a great job GOOD LUCK!!!!! SignedTaz
Nov 01, 2010 | Coleman Powermate 60 Gallon Air Compressor
Trying to replace a power window motor on an 03 maxima but can't get motor assembly out from behind door and now window is off track as well. Need to know how to get window back in track. Do I need to...
The window need to be lowered to get to bolts that hold it to regulator,then pull glass all the way up and wedge it there,next is to remove all the bolts securing the regulator to door,now work regulator out and replace the motor, with regulator out remove the wedge tilt glass until you are able to get it on the front and rear track ,on track now pull window back up and wedge it.install regulator and bolt it up to door,move regulator with switch to line up bolts to attach glass, now lower glass onto regulator arms and tighten, hope this helps.
Sep 12, 2010 | 2004 Nissan Maxima
I have a 2004 Tahoe which has misfire problems (P0300). I changed the plugs, wires, fuel filter and air filter but problem still exist. The 4 plugs on the passenger side continue to file out and become...
Removal & Installation of fuel Regulators on
4.8L, 5.3L & 6.0L Engine To Remove:
CAUTION
Three styles of fuel pressure regulators and fuel rails will be used in this model year. Each regulator has a different "footprint" that consequently changes the size of the receiving port in the fuel rail. The regulator retaining clips are specific to each rail-regulator design and cannot be interchanged.
  1. Remove the engine sight shield.
  2. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
  3. Clean the fuel pressure regulator retainer and the surrounding area.
  4. Remove or disconnect the following:
    • Fuel pressure regulator vacuum line.
    • Fuel pressure regulator retainer.
    • Fuel pressure regulator.
  5. Remove the following parts from the fuel rail:
    • Backup ring (10)
    • Regulator Seal O-ring (11)
    • Regulator filter (12)
    • Regulator seal O-ring (13)
To Install:
  1. Make sure the NEW fuel pressure regulator retainer is the right one.
  2. The tabs (1) are used on the straight vacuum port retainer (2), and the E85-straight vacuum port retainer (3).
  3. The angle vacuum port retainer (4) has no tabs. chevy_aval15_02-04_fuelrail.gif
  4. Install the following parts onto the fuel pressure regulator (9).
    • Backup ring (10)
    • Regulator seal O-ring (11)
  5. Lubricate the fuel pressure regulator O-rings with clean oil.
  6. Install the fuel pressure regulator and retainer. CAUTION
    Whenever the fuel pressure regulator is removed from the fuel rail NEW O-rings and a NEW retaining clip should be used on reinstallation.
  7. Connect the vacuum line.
  8. Tighten the fuel filler cap.
  9. Use the following to inspect for leaks:
    • Turn ON the ignition, with the engine OFF, for 2 seconds.
    • Turn OFF the ignition for 10 seconds.
    • Turn ON the ignition, with the engine OFF.
    • Install the engine sight shield.
8.1L Engine To Remove:
Fuel pressure regulator vacuum line gm_trk_sub15_fuel_press_reg_vac_line.gif
  1. Before servicing the vehicle refer to the precautions at the beginning of thjs section
  2. Remove the fuel injector sight shield as needed
  3. Relieve fuel system pressure (See: Fuel Pressure Relieving)
  4. Disconnect the fuel pressure regulator vacuum line (A) 8.1L Fuel pressure regulator retainers gm_trk_sub15_81l_fuel_press_reg_retainers.gif
  5. Clean any dirt from the fuel pressure regulator retainer and the surrounding area
  6. Remove the fuel pressure regulator retainer (I)
  7. Remove the fuel pressure regulator (H) from the fuel pressure regulator housing
To Install:
  1. Install or connect the following:
    • Backup ring (J) on the fuel pressure regulator (H)
    • New large O-Ring (K) on the fuel pressure regulator
    • Regulator filter (L) on the fuel pressure regulator
    • New small O-Ring (M) on the fuel pressure regulator
  2. Lubricate the fuel pressure regulator large O-Ring and the small O-Ring with clean engine oil
  3. Push the fuel pressure regulator onto the regulator housing on the fuel rail
  4. Install a new fuel pressure regulator retainer (I)
  5. Install or connect the following:
    • Negative battery cable
  6. Tighten the fuel filler cap
  7. Inspect for leaks using the following procedure:
    • Turn on the ignition with the engine off for two seconds
    • Turn off the ignition for 10 seconds
    • Inspect for fuel leaks
  8. Install the fuel injector sight shield
  9. Road test the vehicle to check performance
Sep 02, 2010 | Chevrolet Tahoe Cars & Trucks
I have an older Craftsman Air Compressor and the knob valve to reg the pressure seems to not be working. Can I replace it?
It is getting increasingly more difficult to obtain replacement parts for older compressors. If your regulator failed at a fairly high pressure adjustment, say around 100-120 lbs, you could just leave the old regulator in place and add a regulator when needed to one of the quick connects. Purchase a generic pressure regulator from Lowes and add quick fittings to easily connect the regulator or remove when not needed. You could also just remove the old regulator and work-in a new generic regulator in its place. Generic regulators sell for $20 - $40. Good luck with your repair.
Aug 06, 2010 | Craftsman Air Tools & Compressors
Need to replace fuel regulator on 96 chevy c1500
the regulator is part of the injector block. You will need to pull the upper plenume to gain acess to it.
Oct 11, 2009 | 1996 Chevrolet C1500
Thermos Grill2Go Gas Grill 4656110 Logo
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
