Question about Python Vehicle Parts & Accessories
Remote start keeps restarting - shutting down and restarting
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
Our requaired is without any in puts(remote start and Manula Start) AC staret after power restart,please gaide to me.
first you need to check if your A/C has Auto Restart function. How?- turn power On from the circuit breaker, if the A/C unit start working at your last-time program you have the Auto Restart function. In that case you never shut it down by the cutting off the current, forever turn it on/off by the remote controller.
Feb 23, 2011 | LG Heating & Cooling
Car starts for two seconds shuts down trys to restart three times with same results
code program wire (pink) was left unpluged after programing code.At restart it would lose code. Reset code pluged in wire,runs fine
Feb 06, 2010 | Viper Security and Remote Start System...
While starting the car with a audiovox remote starter the car starts up and runs about a second and shuts off and tries to restart and once again it stalls other wise when you start the manually the car...
all remote start alarms must see that the engine is running usually from a coil sense wire this is obviously not connected as your alarm keeps trying to restart
Sep 20, 2009 | Vehicle Parts & Accessories
My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
How to keep number lock on after comuter is shut down and restart
  1. Start the registery editer (regedit)
  2. Go to HKEY_CURRENT_USER \ Control Panel \ Keyboard \
  3. Double-click the value InitialKeyboardIndicators, and enter 2 as it's Value data
  4. Close the registry editor
  5. Log off, or restart Windows for the changes to take effect
Dec 16, 2008 | Dell Inspiron 6000 Notebook
I am trying to reboot my acer laptop
have you tried configuring the BIOS to its default setting or setting it to its optimized default. and then restart. if still doesn't work out change the CMOS battery. if you need driver try this website  www.driver.com
Nov 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspireā„¢ T180 PC Desktop
Vehicle Parts & Accessories Logo
80 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
AzVip
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
