Question about Dayton Heating & Cooling
Dayton 100000btu tube heater won't fire - Dayton Heating & Cooling
tbugger
  • 232 Answers
SOURCE: DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Posted on Dec 08, 2008
farfield
  • 462 Answers
SOURCE: dayton kero heater wont fire0
OHH I bet this is the same question I just posted to. So it is a forced air kerosene. The usual is like I said a blocked combustion air hole. It could also be something shorting out the spark ignition to ground when replaces inspect the wires and look for a week or loose ground in this case. Sorry about the confusion.
A Bad ignition proving circuit or something like (what we call here dirt dobbers) hornets nest could be letting the flame hit it and not allowing full flow through the heater. Mice are also notorious for making problems like wires chewed and nests in the wrong place. Given where it may have been stored.
Posted on Mar 04, 2009
  • 33 Answers
your photo cell is bad or dirty its a little lens that looks threw the hole into the cumbustion chamber with two wires coming out of it.
Posted on Oct 28, 2009
koolbreezes
  • 540 Answers
SOURCE: Reddy Heater 100000BTU no ignition
Time for a full servce overhaul - kit at your lawnmower supply house.
Posted on Dec 18, 2009
  • 832 Answers
SOURCE: 100000Btu Reddy kerosene heater fires up then
1. Check the fuel nozzle if it produces an atomized
spray of the kerosene all the time.
2. If it doesn't atomize, pls check the fuel pump, it is
working right.
3. Your igniter is working, since it fires up.
Check item 1 & 2 must be satisfied to get it to working
condition. Hope this help.
Posted on Jan 06, 2010
Is Dayton electric heater # 2e669a a 110v or 220v
I can't find that model number. The closest I came was this page. Some heaters are 110, some are 240. I couldn't find a manufacturer page either.
Dayton Heaters Electric Oil Fired Gas Fired Heating Solutions
Oct 28, 2015 | Dryers
I need a fuel filter assembly for a Dayton Oil Fired heater - part #099743-01. Do you have a supplier??
Dayton Heaters are sold by Grainger. If parts are available, you can order them from their parts department.
Jan 02, 2015 | Dayton Heating & Cooling
100000Btu Reddy kerosene heater fires up then shuts down after a few seconds to a few minutes
working right.
Jan 06, 2010 | Heating & Cooling
100000BTU Kerosene (no t-stat) Fires up and works intermittantly
The fuel leak must be corrected since I believe this is
connected to the fuel supply at the nozzle at the firing
area. Fuel nozzle must be atomize all the time to keep
it burning, otherwise the operation stops. This is what I
know from experience. May this info help you.
Jan 06, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Dayton kero heater wont fire
Jan 15, 2009 | Dayton Electric Heater
Won't light/stay on
It may be the spark plug (or the ignition module). On my Reddy Heater 50K BTU, there are six metal screws that join the top of torpedo tube to the bottom. Remove these,and the top of the tube casing. The spark plug should be in plain sight.
Turn the unit on and look for spark. If it's not firing, replace the plug. If it still doesn't fire, you may need to replace the ignition module (it's what is "connected to the spark plug via the fat ignition wire.")
Hope this helps,
Jan 06, 2009 | Dayton E50 Heater
Dec 08, 2008 | Dayton E50 Heater
Dayton 600,000 btu heater oil fired
throw a gas can in a fire it is alot more fun.call the manufact
Jan 02, 2008 | Dayton E50 Heater
Heating & Cooling Logo
29 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
