Question about JVC CH-X400 12-Disc CD Changer
Cd is not turning when cd's are selected -1through 12
How do i start the magic square 5x5 1through 25 with 25 in the right corner
Here is a good discussion on solving magic squares, with an example of your problem. http://www.jonathandimond.com/downloadables/Magic%20Squares.pdf
May 01, 2015 | Office Equipment & Supplies
How to enter unlock code consisting of pw+code+1# on Nokia Lumia 810, when the keyboard only has numbers 1through 9
To use special keys, press the key on the bottom left (3) on the image.
It is al in the manual, you grew away because you thought you did not need it. fb61b802-718a-4c01-ac08-7f559cd33dcb.png
Jun 19, 2014 | Cell Phones
What station does the 12 cdx run on?
according to pioneer their are 12 FM frequencies (stations) they start at 87.9 mhz and go to 90.1 mhz (fm) in0.2 mhz steps select with your remote. and set station and enjoy your music.
Sep 23, 2012 | Pioneer CDX-FM1287 12-Disc CD Changer
I have a wurltzer CD 100 disk player. I think the
Either the CD player, CD control unit, or Selection & Credit Computer are defective. I can help over the phone with troubleshooting, please email tech@wurlitzer-ohio.com.
Jul 30, 2010 | Wurlitzer Jukebox CD Player
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
Clock
Setting the time
This is used to set the time on the unit’s clock
display.
1 Press SOURCE and hold until the unit turns
off.
2 Press AUDIO and hold until TIME (12:00)
appears in the display.
3 Select the portion of the time display you
wish to set with left\right
Pressing left\right will select a portion of the clock
display:
HOURMINUTE
As you select portions of the clock display the
portion selected will blink.
4 Select the correct time with up\down.
Pressing up will increase the selected hour or
minute. Pressing down will decrease the selected
hour or minute.
• To cancel time settings, press BAND.
• You can also cancel time settings by holding
down AUDIO until the unit turns off.
Jul 17, 2009 | Pioneer DEH-14 CD Player
Distributor cap wiring diagram
Check this info... Wiring Diagrams with the graphic firing order for 6 and 8 cilinders.
Good luck!!!
Apr 22, 2009 | 1993 Jeep Grand Cherokee
Amp turns off
your radio has 2 blue wires. one of them provides a 12 volt turn on for a power antenna (when a cd is inserted that 12 volt turn on turns off, because when a cd is playing, the antenna doesn't need to be raised up). The other blue wire has a 12 volt turn whenever the radio or the cd is turned on--this is the blue wire that you need to connect to your amp remote line. ( pull out the radio and switch the blue wires)
respectfully,
Merle
Sep 12, 2008 | Kenwood KDC-MP4028 CD Player
NEDD TO KNOW HOW TO WORK THE FADE CONTROL
Press the <<,>> button and select "Fader".
Turning the Rotary knob clockwise fades the sound to the front; turning the knob counterclockwise fades the sound to the rear speakers.
The display changes as follows:"Front XX" will be displayed where "XX" is the value from 1 to 12.
"Rear XX" will be displayed where the "XX" is the value from 1 to 12.
When fader is 0, "CENTER" will be displayed.
Jan 04, 2008 | Clarion DB175MP CD Player
JVC CH-X400 12-Disc CD Changer Logo
21 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
