Question about Honeywell Televison & Video
Honeywell Model RT8220A Transmitter, worked fine till batteries where changed. Shows room temperature then after 5 seconds change's to a screen of 8's then back to temp and vice versa
  • 11 Answers
SOURCE: Bose RC28S
Try the samsung code.
Posted on Jun 08, 2010
SOURCE: I have a honeywell remote
Push the up and down arrow keys on your remote simultaneously for at least 3 seconds to toggle between Fahrenheit and
Celsius units.
Posted on Oct 24, 2010
BElectric
  • 1140 Answers
SOURCE: I have a Vermont Casting
It's unlikely that you need a new remote. It simply needs to be reprogrammed with the correct code again. Remotes can "forget" the programmed codes if the batteries run down completely or if the new batteries aren't inserted quickly enough.
Reprogram the codes and it should work.
Please post back if you need further assistance.
Regards,
BElectric
Posted on Dec 07, 2010
  • 76 Answers
SOURCE: G3T-BX
check manual for erasing codes and reprgraming remotes should be something about a learn button
Posted on Oct 21, 2012
mbomhoff344
SOURCE: We need to replace our
I have one if you still need one. Let me know.. I can sell it to you for $100 (includes your shipping) :) Thanks--Mike
Posted on Jan 16, 2013
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
I couldn't figure out how to amend my last question, so here is one more piece of information. I just put batteries back in and reset the time/date. The Temp Up and Temp Down buttons WORK FINE
your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up
Jan 31, 2015 | Honeywell RTH230B 5-2 Day Programmable...
Have a honeywell thermo 7 day .how to change for centerage to farenheight
1. Turn system off.
2. Simultaneously press up & down arrows for 3 seconds.
3. You will then see a display with a large number to the left and a small number to the right.
4. You should then see a large #1 and a small #1.
5. You want to change that 1(Celsius) to a 0(Fahrenheit).
6. Do that by pressing up or down arrow.
7. Once you've changed that small 1 to a 0 you then press both the up and down buttons for 1 second about three more times to take thermostat back to original screen.
8. Now you should see your room temperature reading in Fahrenheit.
Nov 02, 2014 | Honeywell TH2110D1009 PRO 2000...
DIY honeywell RTH2310 thermostat does not ignite the furnace after changing batteries. It was working fine until it showed the low battery sign and we changed the batteries. It now shows the...
check wire screws on the base to make sure the wires are snug and the screws are tight. When you snapped the thermostat on to the base, make sure you didn't bend any of the engage pins or loose a jumper clip. When you first put it back it should have made a clicking sound and then reset to the room temperature. You may have to reprogram it if you take too long to put new batteries in after removing old ones.
Oct 04, 2017 | Heating & Cooling
VERMOUNT CASTINGS HONEYWELL REMOTE RT8220A 1032
That link was not posted correct. Try this one to view the honeywell Remote:
http://www.ibuyfireplaceparts.com/20002047-transmitter-honeywell-remote.html
Jan 31, 2012 | Televison & Video
I have a honeywell rth2510 thermastate how can i change from celcious to farenheit
here is a download for the manual on page 12 and 13 in English.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2380ES.pdf
Press the up and down button simultaneously from a few second till display changes and then on #1 set it to option 1 and that show be C.
Feb 21, 2011 | Honeywell Programmable Thermostat Heater
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
Honeywell UtilityPRO thermostat backlight won't go off
After posting that I was having the same problem, I found a solution.
I used these instructions http://www.hydro-temp.com/help/drawings/honeywell%2069-1894ES.pdf and followed the Installer Setup on pages 6 through 10. Basically you just need to enter the setup mode following the instructions, scroll to setting# 280 and change the setting from "1" to "0" then the backlight will turn off after 8 seconds. Don't change any other settings if you don't know what you are doing.
Jul 18, 2009 | Honeywell Electronic Programmable...
No power
check transformer in furnace... thermostats get there power from it....not the room its in
Mar 15, 2009 | Honeywell Electronic Programmable...
Televison & Video Logo
247 people viewed this question
Top Honeywell Televison & Video Experts
mikemail1
Ron Durham
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
