Mitsubishi TV problem
My TV shuts itself off after approx 2 hours use. Once it has "rested" for several hours it can be watched again, but only for a couple of hours again. If it doesn't get enough "rest" the usage time is shortened. Sounds like something is overheating. Any suggestions>
  • 6 more comments
  • Anonymous Apr 02, 2008
    well I don't feel alone
    got the same problem with my Mitsubishi
  • kreg Apr 21, 2008
    Mitsubishi Diamond WD-65831 65 in. HDTV Television
  • Anonymous Aug 11, 2008
    Have the same problem.Been happening for months.Service center can find no problem.
    JB
  • joycecamp Sep 09, 2008
    I have the same problem with my WS 55315 Mitsubishi 55" TV. I bought in in October 2005. Does any one know how much it costs to fix it or if I can fix it myself? All the connections are fine. It just goes blank after a couple hours watching it, and then if you let it rest, you can turn it back on and the picture and sound will be back.
  • Anonymous Dec 06, 2008
    I have the same problem. Just had my tv repaired and after a day it start to do the same thing.
  • ehuff2001 Dec 06, 2008
    I have Mitsubishi 60 in Model vs606507 and tv turns off and picture was flipping. Had tv repairman fix the tv. The tv stopped flipping but after a day it start to shut off after 4 hours then it will turn on and shut off within 10 mins.The time varies. Tv repairman came back out took mother board and could not diagnose the problem.
  • Anonymous Dec 07, 2008
    HI My 60 inch mitsubishi projection TV- model number vs 60719 ( 6 years old ) will go to a black screen-sound starts to crackel- so we lower the sound -some times it comes right back on -sometimes it will go on and off a bunch of times -and then come on for an extended amount of time (days )-- then goes thru the same cycle again-this has been happening now for about a month and a half--repair man says he cannot guarentee a fix-for 500 dollars--- Any help is greatly appreciated--tonyandginny @tampabay.rr.com -thank you for yor help in advance---TONY
    HI My 60 inch mitsubishi projection TV- model number vs 60719- MEDALLION 60 INCH ( 6 years old ) will go to a black screen-sound starts to crackel- so we lower the sound -some times it comes right back on -sometimes it will go on and off a bunch of times -and then come on for an extended amount of time (days )-- then goes thru the same cycle again-this has been happening now for about a month and a half--repair man says he cannot guarentee a fix-for 500 dollars--- Any help is greatly appreciated--tonyandginny @tampabay.rr.com -thank you for yor help in advance---TONY
Where is the oscillaion circuit?
I'm having the same problem. TV only works if my A/C is on so I'm thinking something is overheating inside.
Posted on Oct 07, 2008
Same problem!! How do you fix this problem
Posted on Sep 21, 2008
  • 790 Answers
Your unit is lack of oscillation! thats why your unit turn off it self! maybe change value of resistors or capacitors... or maybe lost contact to oscillation circuit....
Posted on Sep 28, 2007
Tv Shuts off By Itself
When something like that happens the problem is probably in the power supply section of the receiver.
Jun 20, 2016 | Mitsubishi Televison & Video
Heating up, shuts off, Shutting off going about an 1 hour trip. hearing small noise in front of engine. Seams to be running hot. service techs put it on dyna but no results. Shut off again next trip. ran...
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
Aug 30, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Wd-62628 video freezes, audio stops, 30 sec later TV shuts off
Intermittent problems are the most difficult to find because they don't show up long enough to trace them down. Today the digital sets are all cpu controlled and a glitch from any board can lock up the set. The problem can even be software related, such as settings or firmware updates. Unfortunately we as technicians do not have a history of symptom/cause on the newer digital sets. Your best bet is to e-mail Mitsubishi with the symptom as described above, such as the blinks, E2P, signal source etc ... and ask them what they think. techservice@mdea.com good luck
Jan 31, 2008 | Mitsubishi WD62628 62" Projection HDTV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Televison & Video Logo
603 people viewed this question
Top Televison & Video Experts
