Depo Auto Parts Jeep Liberty New Radiator/Condenser Cooling Fan Motor 3.7 Liter without Tow Package 2002 2003 2004 OEM 55037659AA Logo
A
Anonymous Posted on Oct 17, 2013
6A5CAP car jump as you like wave and continue
When I put batteries in and turned it on, it started smoking and a wire heated up very quickly. Is there anyway this one candle can be replaced because it is a manufacturing flaw?
Search Results
    Smoking battery and wires HELP - Moderated Discussion Areas ...
    continuouswave.com/ubb/Forum6/HTML/001938.html
    Jun 13, 2008 - 10 posts - ‎5 authors
    The motor started to turn BUT the battery began to smoke , the wires ... Set the dial on the continuity function and put the leads on each of your battery cables. ... Thebatteries and cables are not reported to heat up when first connected. ... button verybriefly and get ready to pull the pos cable quickly in case ...
    Smoking Battery Cables - Moderated Discussion Areas - Continuous Wave
    continuouswave.com/ubb/Forum6/HTML/001003.html
    Jul 19, 2006 - 24 posts - ‎9 authors
    Are the terminals on battery cables supposed to be hot? ... amounts of resistance cause significant heating, which is why battery cables need .... Yesterday I went out and hooked up the new battery, turned the key and got absolutely nothing. ... Good thing I had the cowling off because a wire started smoking.
    Why did my Jumper Cables burn in half after attempting a jump
6a5cap on dashboard means??
where? (the dashboard is 2foot by 5feet, must i guess?)
the display? in the digital display , or is that a radio model number.
try to be more clear, say exactly where seen....
im looking in your operators guide. (nop there there)
http://www.jeep.com/en/owners/manuals/
is that the radio display or dash speedo cluster errors?
surely you know
or post a photo. all cell phones have camera/s free.
or the clock error?
the EVIC display, usually shows English simple words like "Glass"
point to an object on the dash and say xxxxx here.
or a photo with finger pointing.....
If i play music through "sound"folder it stops after playing only one song, i have to agian press 'next botton, but it plays continues if played through Music on the screen bourd but the quality...
you cannot play songs in a particular folder. One thing you can do is
launch music player>albums>select the album you wanted to play continuously.
Regards
Wave User
2006 Pontiac Wave jumps out of gear.
it might be the start up gear or the transmission or engine might need to check the oil. i think that the transmission needs replacing.
2helpful
Wave in my LCD Flat Screen
try a dvd on your tv.sounds like a signal source problem.if you see the wave playing a dvd then you have a defective digital main pcb or the panel is going bad.
2answers
When I play cd's the music jumps
Make sure the speakers aren't too close to the CD player. The sound waves could be causing it to jiggle around like Elvis singing Blue Suede Shoes.
2helpful
Bose wave muoti cd changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will have to be disassembled to get the CD out and the unit itself will need to be serviced (rebuild and retime cd changing mechanism)
Top Depo Auto Parts Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
