Question about Kyocera Mita FS-1030D Laser Printer
Kyorcera FS1030D error - Kyocera Mita FS-1030D Laser Printer
2 Suggested Answers
SOURCE: Kyorcera FS1030D - error light sequence
Dave,
You need to empty the excess toner reservoir in the front of the process unit.
Front as in the other end to where you put in a new toner.
All you have to do is open the side panel and empty all the toner out.
That should fix your problem.
Sorry to give you all the instructions like this but people still open up the toner end and have a lot of fun putting it back together.
Enjoy
Posted on Apr 23, 2009
Just bought a Kyocera FS-1030D laser printer. what do i need to do or need to connect it to my laptop. have power cable but no disks
I looked up the specs this has a usb 2.0 interface so you need a usb printer cable. it has a parallel interface but this is an older technology and your computer most likely does not have a parallel port.
you need to download the driver see http://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.FS1030D._.EN.html
windows os may have a driver already.
Jun 16, 2015 | Kyocera FS-1030D Laser Printer
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Where can I find driver for KYOCERA FS1030D for MAC OS X LION ?
hi,
here;s the download center for kyocera you can download here the driver for your printer.just follow this link good luck!
Aug 11, 2011 | Kyocera FS-1030D Laser Printer
Dear sir / madam many times when i print, the printer give white paper and this error pcl xl error subsystem : kernel error illegal tag operator ox8 position 30374 what i must do thanks
try a different driver
pc5
pcl 6
and kyocera own kpdl or kx
or even a mini driver
here is the link http://www.kyocerasupport.co.uk/index/download_center.false.driver.FS1030D._.EN.html
if all fails u might need to upgrade firmware on the printer
Nov 20, 2010 | Kyocera FS-1030D Laser Printer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Dave,
Enjoy
Dec 15, 2008 | Kyocera Mita FS-1030D Laser Printer
I cannot take prinout from kyocera FS1030D from my laptop
make sure you have the correct driver for your laptop operating system and you have a usb2 cable
Dec 03, 2008 | Kyocera FS-1030D Laser Printer
PAPER JAM IN VERY REAR OF PRINTER KYOCERA FS1030D
sounds like a fuser jam. remove top and side covers, then rear exit tray. remove fuser screws and connectors. should be able to remove paper with fuser out of machine.
Oct 08, 2008 | Kyocera Office Equipment & Supplies
How to print configuration page for a Kyocera FS1030D
Try press and hold the green button for about 10 seconds. HOPEFULLY this will cause the printer to produce a configuration page with the details. Good luck!!
Sep 25, 2008 | Kyocera Mita FS-1030D Laser Printer
Kyorcera FS1030D - error light sequence what does it mean
If you mean that the sequence is: 2nd led and then 1st+2nd+3rd
the problem is in fuser unit. You have to call a technician to check the lamp, the thermistor and the thermostat inside the fuser unit
Mar 16, 2008 | Kyocera Mita FS-1030D Laser Printer
Kyocera Mita FS-1030D Laser Printer Logo
20 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
