Question about Citizen Chronograph Watch
What is the battery size of a pulsar Y651-506A watch.
What kind battery does a pulsar pj6054 take?
have you check the bottom of your purse .that where wife usually find lost little thing EH!
Jan 29, 2015 | Pulsar Watches
What type of battery does a Pulsar pxh227 watch take?
The Pulsar pxh227 uses a sr920sw silver oxide battery. An AG3 alkaline battery will also work, is cheaper, but will not last as long as the sr920sw.
Oct 12, 2013 | Pulsar PXH227 Wrist Watch
Pulsar solar watch repair, stopped running
They have a rechargeable battery in them,you'll have to go to jeweler or a watch repair store.the battery is not cheap!!! I had my wifes fixed a few years ago the battery cost $68.00,but she likes the watch so it was worth it.
Jan 17, 2013 | Pulsar Watches
Which watch battery fit my Pulsar?
372 or 373, they are interchangeable. It was listed under Seiko and not Pulsar.... the key model # is the vx43, the rest wasn't used. My source: MAXELL 373 SR916SW 1 Battery Official OEM 372 373
Feb 28, 2012 | Seiko Watches
Lost stem on watch. can i get replacement? can i install myself?
mcdevito75 Here, Pulsar a quartz watch. If you lost the stem, the mechanism holding it into the watch maybe damaged, this mechanism also turns your Pulsar watch on / off. Best Bet, visit a small watch repair shop in your area, have them take a look at your Pulsar watch. You could replace the stem yourself but first you"d need the right size stem, (hard to get) then if the mechanism holding the stem in is damaged you"ve wasted your time. Your local small watch repair shop can let you know, and they usually don"t charge to have a look.
Feb 05, 2011 | Pulsar PXH227 Wrist Watch
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
Jul 03, 2010 | Seiko Pulsar watch
I can't open the back of my watch to put a battery into it
If you don't have the right tools don't even try - you'll risk damaging your nice watch. Instead, take it to a watch shop or jewelry store (Sears does it too) and let them do it with the right tools, correct battery and - very important - a new gasket to keep it water resistant. Cost for the battery replacement is about $8.
Apr 28, 2010 | Seiko Pulsar Europa Ladys Size PXQ495...
Battery problem
Stop panicking, please. If you lost the battery, that means your watch has been opened, so, read the movement number and submit here. Then Ill be able to give exact battery number.
Apr 14, 2010 | Pulsar Expansion PPH520 Wrist Watch
I have a Seiko stainless steel ladies watch, 3 years old, only one 'winder' no fancy buttons, analogue style. It has suddenly started beeping every hour - how do I turn it off?
mcdevito75 here, The beeping must be a signal that the battery is weak, have the battery changed. Look for a small watch repair shop in your area for the battery change.
Nov 05, 2009 | Pulsar by Seiko watch PEG665Ladies...
I don't know what size battery my pulsar watch uses
OPTIONS:
1. Owners manuel
2. Take watch to walmart(or other) and have them replace bat (usually, no labor charge.
3. Bat is sometimes stenciled on case back (very small)
4. Open watch(IF YOU KNOW WHAT YOU'RE DOING) you can easily ruin watch. Check # on old battery or if missing check inside of back case
for # .
Sep 26, 2009 | Bulova Watch
Citizen Chronograph Watch Logo
62 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
