Question about Mitsubishi VS-60111 60" Rear Projection Television
Not turn on i do not have 24v. - Mitsubishi VS-60111 60" Rear Projection Television
  • kellyact Dec 09, 2007
    Watching TV and it turned itself off, will NOT turn back on. Had the IC converter changed 2 weeks ago! Perhaps it was a bad one!
Same problem here tv 60" projection TV. I can not turn it on. how can I check the fuse and coolent
Posted on Jan 10, 2008
  • 1,694 Answers
Open pico fuse caused by short circuit. Check for coolant leak from CRT on PCB.
Posted on Sep 26, 2007
  • Vista Electronics Oct 19, 2007
    Often, an open fuse device is caused by bad convergence IC's.
    Have you made any progress on the repair of your Mits??
    I would be happy to help.......T.
Standby light is on but doesn't turn on! Measure the 24V on turning on but losses it!
Most TVs shut off automatically if there is no input signal. This would also explain the lack of screen image.
Jun 23, 2014 | Coby Electronics Corporation Coby...
GVA-24V valve actuator keeps rotating constantly
try to click handle by turning till it clicks into groove
Mar 24, 2013 | Goldline Controls Goldline GVA-24 - Valve...
Do i need to turn my 24v 200w kids razor sccoter on to charge it? and how long do I charge it for?
no it doesn;'t need to be turned on to charge it, it should usually take about 8 hours to get a full charge
Jun 28, 2012 | Electric Eyeware 24 Volt Battery Charger...
Gas furnace gmt090-3a, has a one link code. the electric gas gas does not get 24V usually. problem is intermittant, wiring appears good, no kinks, or fraying. bypassing the thermo sensors for the 24v...
Sound like you have figured it out. Good job. I suggest that you verify the results next time that it fails. When it fails. measure voltage at the "w" terminal on the circuit board. If 24 volts is present here and not at the gas valve terminals then you are absolutely correct. It is the circuit board.
Dec 18, 2010 | Goodman GMS90703BXA Heater
Usually that is because of a blown fuse in the air handler or fuenace which ever you have or the transformer that supplies the 24v to the thermostat, also in the air handler or furnace, has gone bad...
Check to see if you have 24v at the transformer and then flow it from there...
Aug 10, 2010 | Heating & Cooling
Hi, my akai 32 lcd tv turns on but no picture
check if you have 24v in ballast board. if you have 24v in ballasts board the board is bad, if not the power suplly is bad.
Jun 19, 2010 | Akai LCT3285TA 32 in. LCD Television
My irC-3200 cannon just show me this error E012 number on the display screen so i want to know what this code mean??Please help me
E012-0001 Error code At about 37 sec. after the power is turned ON, due to a drum ITB motor failure
Symptom About 37 sec. after the power is turned ON, E012-0001 is displayed due to a drum ITB motor failure. Cause Rotational failure of drum ITB motor Items to Check 1) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR, enter 1 and press the OK key.
2) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR-ON, press the OK key to check whether the motor is working normally.
3) Check whether 24V is supplied to J93 on the ITB drum motor. If yes, the ITB motor likely faulty.
4) If 24V is not supplied to the ITB drum motor, check whether 24V is output from fuse PCB J70-3 to the ITB drum motor.
Also, check whether 24V is output from the fuse PCB J71-1 to the microswitch PCB and also whether 24V is supplied to the fuse PCB J71-2 from the microswitch PCB.
5) If there is no problem between the fuse PCB J71-1, -2 and the microswitch PCB, the fuse PCB is likely faulty.
If 24V is output from the fuse PCB J71-1 to the microswitch PCB and not supplied to the fuse PCB J71-2, check the microswitch PCB. Field Remedy Replace the drum ITB motor.
FH6-1971 DC Brushless Motor
Sep 01, 2009 | Canon Office Equipment & Supplies
Different color leads in transformers
No, it doesn't matter. If you want to make sure hook up the leads to the 120 side and then turn on power and check the leads coming off the low voltage side to make sure you getting the 24v before hooking it into the board.
Jul 31, 2009 | Heating & Cooling
Mitsubishi VS-60111 60" Rear Projection Television Logo
173 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
